| Chip Amps Amplifiers based on integrated circuits |
TDA7462 2.1 Audio amplifier
Finally I finished this project ( well almost problem with case... ). It is 2.1 audio amplifier built around TDA7462D SGS audio processor chip. I used TDA7294 for sub amplifier, and 2xLM1875 for satellites. The MCU is ATMEL 89c55wd (8051 with 20Kbytes flash memory). I have a few pictures in very low resolution, sorry! ![]() sub.zip |
#2 |
This is NICE.
#3 |
the zip file is not opening , i am trying to build a 2.1 system with exact specs for the amp , need help with configuring tda7462 parameters , not sure if the subwoofer output is filtered and if the fc can be changed ,
#4 |
OK this is the link to the Serbian HI-FI forum (sorry!!).
http://www.hifi-forumi.com/forum/vie...hlight=sub2005 I will upload some more quality pics later... Anyway, the project isn't completed jet (mechanic#$#@$#)The subwoofer output can be filtered and you have two fc (I think 90Hz and 115Hz...) Some measurement results: http://galeb.etf.bg.ac.yu/~gaja/treble%20_LP.png http://galeb.etf.bg.ac.yu/~gaja/treble_dw_10KHz.png http://galeb.etf.bg.ac.yu/~gaja/treble_up_10KHz.png http://galeb.etf.bg.ac.yu/~gaja/trebleCF.png http://galeb.etf.bg.ac.yu/~gaja/tda7462d_mon_out.htm |
#5 |
Very nice stuff!!!
#6 |
thnx for the link , thai is really good , i am planin to build pc interface for 7462 control ,
#7 |
i am workin on some thing similar butmy board is nt as compact as yours some how.. bu t i have have used a TDA7439... and TDA7265 on the same board.. and 89s52... with a JOG wheel.. and a few buttons.. but my problem is the transformer rating can you help with it... how much current 3 amps total or 4.5amps total
#8 |
ru planing for a torroid or EnI trns ? how much current 3 amps total or 4.5amps total , what exactly u mean by that
#9 |
Yeah thats what i know i need a 25volt ac center tapped transformer but how much current as the peak out put current is limited at 4.5 amps. And also if i go for a Tori... How much will it cost and how much expense for e.i. Core. Where are you from bombay or some place else
| Schematic: Audio Innovations, The first audio amplifier | maartentje | Tubes / Valves | 22 | 25th February 2010 06:34 AM |
| Audio Amplifier | wkahc | Introductions | 1 | 31st August 2007 06:01 PM |
| Car audio Amplifier | willo | Car Audio | 12 | 26th October 2005 03:58 PM |
| Audio Amplifier Help pls | silverferro | Everything Else | 0 | 26th August 2004 10:15 AM |
| audio amplifier | mephisto | Car Audio | 2 | 21st January 2004 04:52 AM |
| Page generated in 0.14570 seconds (54.79% PHP - 45.21% MySQL) with 10 queries |
