Old 3rd June 2006, 06:37 PM   #1
ash_dac is offline ash_dac  United Kingdom
Default Chipamp for computer - which one ?(need about 4W X 2)
My pc speakers are nearly dead. (4W X 2 from 12V walwart)
Could I use the Lm3886 on a reduced powersupply ?
http://www.national.com/appinfo/audi...gn_Guide15.xls (The spreadsheet tells informs me that I can't use less that +-10V. However, the datasheet shows THD on 0.1, 1 watt with another graph showing that it may clip at reduced voltage).
Tdaxxxx chip amps have much worse poorer supply rejection ratio compared to the LMxxxx series so I would expect more distortion, layout problems, and oscillations.
I have ordered three Lm3886 for future projects but i'd like a recommendation of a chip amp for low power applications.
Old 3rd June 2006, 07:39 PM   #2
ted is offline ted
Using a lm3886 or something within that family may be overkill. For simple, bullet proof amplifiers I use the lm4752 / lm4755. They have 2 channels, and few external parts. You are not going to win any sound quality awards with the 4752/4755 but I prefer them over some the tda options.
Old 3rd June 2006, 07:46 PM   #3
joensd is offline joensd  Germany
I wouldnīt say itīs overkill really.
You can get it almost anywhere (+PCBs), itīs simple to implement (say well behaved) and not that expensive likewise (see trade forum; just got some).
That said they indeed need 20V minimum.
A chip I often heard and seen implemented in PC amps is the TDA2030.
Itīs also on the edge with 12V (AC or DC?) but should work and has a nice sound.
Better yet get the new version the TDA2040 (voltages from +-2.5V) or the TDA2052 (as TDA2030: +-6V)
jens
Old 3rd June 2006, 07:49 PM   #4
if your not set on DIY you might want to consider an SI, although you will want to watch the voltages from that wall wart with any T amp.
Old 3rd June 2006, 08:34 PM   #5
Send a message via MSN to Irwin AR
I think this might suit you just fine
http://translate.google.com/translat...lr%3D%26sa%3DG
Old 3rd June 2006, 09:16 PM   #6
Lm3886- If I used a DC-DC convertor I could get -12V.
I'm not sure that there would be enough current for any output!
Any thoughts ?
edit: just looking at LM384
Old 3rd June 2006, 09:40 PM   #7
that depends on the wallwart and the circuit you wanna use.
Hmm, donīt know how much effort youīre willing to input
but I personally would rather keep it simple and go with a TDA2040
or alternatively getting another power supply/transformer for the LMīs.
One TDA2040 should cost ~ a quid, a little transformer for the LMīs from salvaged equipment (printer wallwarts, audio amps, lighting transformers..) can often be had for nothing.
The DC-DC converter will cost a bit and some nerves too to get it properly working and is nothing for a first time project anyway.
You decide.
uhh, had one of those and a LM386.
I remember they were a pain to get working noise-free.
They both have fixed gains so youīd have to lower the input signal quite a bit which is not very advantegeous in your application.
jens
Old 4th June 2006, 11:39 AM   #8
I've been digging around on the forum, and on the net this morning, and I have come to the conclusion that -
L165 = LM1875 = LM675 = tda20x0 (close)
I forgot that a speaker is really a motor
The only reason I'm a bit wary of making the psu is the fact that I see numerous examples on this forum, and on the web of DIY power supplies that look frankly leathal !
I will have a look on the web for a book on how to safely build power supplies.
Old 4th June 2006, 02:17 PM   #9
If you donīt plan on further DIYing it can indeed be a bit involving reading about power supplies, safety issues, etc...
Another solution as already mentioned might be to find another wallwart with a bit more "juice" and voltage.
I used a HP printer wallwart for a PC amp once.
They usually have almost 30VDC at 1A. If you could find two:even better.
jens
Old 7th June 2006, 07:00 PM   #10
Lm3886 arrived yesterday.
I have gutted a NAD3130 (terrible insides) chassis to put the boards in.
I have been using the overture design guide (model) using 8 ohm load, and 18V secondaries with 40C ambient temperature.
The model recommended a heatsink of 5.94C / W for the TA package. This seems quite high to me but I guess this must reflect the 8 ohm load. Any thoughts on this ? It would certainly save on the heatsink costs.
I plan to have the heatsinks isolated form the case, and run them live.
I put the LM3886 onto stripboard (diagonally as recommended elsewhere on forum).
Appropriate chipamp for HT2 paean Chip Amps 11 8th February 2008 09:15 PM
Chipamp or my NAD nvrgdenuf Chip Amps 9 4th January 2008 11:45 PM
Chipamp'ed Computer Speakers luvdunhill Chip Amps 9 13th July 2006 07:20 PM
5.1 Surround Sound for Computer - ChipAmp DSchmidt Chip Amps 0 24th December 2005 05:22 PM
Simple/Cheap computer speaker chipamp Mr Teal Chip Amps 4 9th May 2005 10:32 PM
Page generated in 0.12351 seconds (79.41% PHP - 20.59% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
