| Chip Amps Amplifiers based on integrated circuits |
#1 | |
I've been reading up on Ohm's Law, and i made up some equasions here for an amp / psu i'd like to make, im not sure how exact the math has to be, so i figured i'd run it past you folks, maybe you can give me a hand
![]() Quote:
o(-_-)o |
#2 |
Looks good... I don't understand why you have R listed in your power supply calc's.
Use I for current in the future... not C. C is used for capacitance. And don't expect to pull 20 Amps from a wall outlet. If you need that much power... change your equipment to 240 V... like a dryer or stove.
#3 |
How many amps should i pull from the outlet? 4 - 5?
o(-_-)o |
#4 |
It might help to know what you are doing?
If your power supply is putting out 243 Watts, it is probably requiring 243 / .95 = 256 Watts at its input. This assumes 95% efficiency... could be lower like 85 - 90% If 256 Watts were going into your supply; what would the current be?
#5 |
2.13 Amps?
o(-_-)o |
#6 |
Yes!
It is important to understand that the wall socket doesn't just cram 20 Amps into anything you plug in. The input to the power supply has a resistance (not really a resistor) that determines what anount of current flows. With what you know... what is the "effective input resistance" of your power supply?
#7 |
Home electrical circuit usually put out either 15 or 20 amps (if we are talking US here) . Unless you are building a 1500+ watt amplifier, however that's not what you should be worried about.
Try going backwards from your amp wattage to determine what size transformer you need. |
#8 |
Ok, using the following variables
P = 256 Watts (What im drawing from my outlet) E = 120 Volts (What im drawing from my outlet) Now that i have 2 Set variables, i can now find the other 2 I (Current) R (Resistance) R = (E * E) / P R = 260.86 Ohms I = V / R I = 0.46 Amps So my effective input resistance is 206.86 Ohms?
o(-_-)o |
#9 | |
-------------------- edit -------------------- Correct me if im wrong, but i should have the output of the powersupply give more power (Watts) than what my Amp calls for right? I know for computers, you should always have more wattage than your computer draws. Thanks!
o(-_-)o |
#10 |
Nope,
You are drawing 2.13 Amps... remember? R = V / I = 120 / 2.13 = 56.3 Ohms |
| double check the math | tenderland | Tubes / Valves | 3 | 27th March 2006 04:48 PM |
| Son of Zen and math | bertjan | Pass Labs | 5 | 10th February 2006 02:51 AM |
| DIY Sub with DAYTON RSS315HF-4 in progress; Can someone check my math? | bcycle | Subwoofers | 18 | 7th February 2006 10:30 PM |
| Can't do the math! | poorstudent | Full Range | 3 | 22nd November 2005 06:37 AM |
| Crossover math check | jmikes | Multi-Way | 6 | 13th December 2004 10:30 PM |
| Page generated in 0.13277 seconds (67.71% PHP - 32.29% MySQL) with 10 queries |
