Old 28th May 2006, 09:34 PM   #1
Send a message via MSN to DoomPixie
Default TDA1554Q Questions....
I have been workign on a TDA1554Q based amplifier (based on the datasheet schematic for the 2x 22W amp) and have a few questions..
1) there is a pin on the chip for powe rsupply ripple regection and in the single ended amplifer int he datasheet it has a capacitor to ground but in the bridged amp it isnt used, currently i am not useing the pin but would it be a good idea for me to ad say a 10uF cap to ground from this pin?
2) I have read most people recomend useing a 10uF electrolutic as input caps but on the datasheet it is a 0.22uF capacitor, i am currently useing a 1uF capacitor (blue thingie, bought a bag of 500 on ebay think they are polystyrene or polyester or something?) and i like the sound but would there be any benefits from changeing to a larger value electrolytic capacitor in this position bearing in mind that they usually sound pretty bad in the signal path?
3) this is one i have wondered about for some time but what able would be best to use from the input rca's to the chip? i usually use shielded signal cable but some people have been saying that a cat5 pair is good... i have loads of cat5 cable so would i be better off useing cat5 or would i be better off buying in some more shielded cable?
many thanks in advance,
Owen
Old 29th May 2006, 11:27 AM   #2
anyone?
heres a link to the datasheet..
HERE
pcb layout tda1554q dce Chip Amps 1 9th November 2010 05:44 PM
TDA1554Q output pins (+), (-) pra3718 Chip Amps 1 28th January 2009 10:52 AM
20+ TDA1554Q 4x11W chips / New speaker Swap Meet 0 1st February 2008 07:18 PM
TDA1554Q Features Wilson2004 Chip Amps 8 15th July 2004 06:28 PM
TDA1554Q and LM1036 question Wilson2004 Solid State 4 13th July 2004 01:56 AM
Page generated in 0.09229 seconds (45.73% PHP - 54.27% MySQL) with 10 queries
