| Chip Amps Amplifiers based on integrated circuits |
Short question:
How do I go about choosing a transistor to serve as the Vbe multiplier to avoid thermal runaway issues? What specs do I want, and how do I go about matching them to the darlingtons I have chosen? Long Question: This is my first post here, but I've been reading for a while, trying to absorb as much information as I can. The LM4702 will be my first project beyond a chipamp, so I'm hoping I can learn a bit about choosing transistors. I would like to build a (relatively) simple amp using the typical circuit schematic in the LM4702 datasheet. It's quite possible that this project is too much for me to handle, but I'm hoping that by narrowing my scope to just the output stage, I'll be able to do it. If this question indicates that I'm in over my head, please let me know. I recognize that most people have chosen to ignore the recommendation of the darlington output stage, but I'm looking for a learning experience, and not necessarily the best amplifier. Anyway, I've run into this issue and I don't really know where to go to find a solution. I understand the thermal runaway issue, and I follow National's recommendations of using a heatsink and emitter degeneration resistors (page 11), and I also understand how a Vbe multiplier, or Qmult as they refer to it, can help solve the problem. How do I choose a BJT to act as my Qmult? Also, if anybody knows of any websites or books where I could learn more about this, I'd love to check them out too. Thanks in advance, Robert |
#2 |
Robert -- I was able to purchase the Sanken power darlingtons from Profusion in the UK -- I received them in less than a week -- here is link:
http://www.profusionplc.com/pro/gex/...%20darlington# beefy little guys with tempco built in. this is a schematic -- showing one channel -- using the LM4702a and SAP16's: ![]() fwiw -- I have 2 versions of the PCB on the way -- one sites the transistors along one vertical plane, the other on two parallel vertical planes. |
#3 |
That is really neat. I had no idea there were darlingtons with built in temperature compensation. Thanks a lot! That should make the project simpler as well.
#4 |
The Vbe multiplier transistor is not critical. Almost any general purpose NPN small signal transistor can be used! It must be mounted on the heatsink near the power output transistors to be effective. Its Vbe needs to be able to follow the thermal variation of the Vbe in the output transistors.
BTW, National Semiconductor have just published a new Application Note #1490 "LM4702 Power Amplifier" in May 2006. The 10 page PDF is available at http://www.national.com/an/AN/AN-1490.pdf Good reading! Glenn Melbourne, Australia |
#5 | |
Glenn -- thanks for pointing this out -- although the link may be broken. |
#6 | |
Rune
Do wizards use spell checkers? |
#7 |
now it's working -- perhaps the server was taxed.
jack |
#8 |
"sounds" like we need a servo -- and have to take apart a 'scope for some mu-metal.
#9 |
I notice the following about the paper: 1. Cin is a Panasonic FC, not a non-polar cap as drawn on the schematic. 2. MN2488 and MP1620 are long obsolete. So are 2SD2488 and 2SB1620 (There must be a dusty warehouse somewhere in NS). 3. No V/A rating for the transformers. I would also say that there should be overload protection and relay, but that is personal I guess. I would trade my tin boxes for the case any day though. Cheers, KK |
#10 |
most important take-away from the paper is the strict adherence to a layout regimen, ground point (not plane), and routing of Sink1 and Sink2 apart.
They may have experienced some EMI/RFI problems with the amp input as there are now 30pF caps on the inputs. |
| LME49810, LME49830 or LM4702? BiPolar or Mosfet output? | sendler | Chip Amps | 27 | 6th March 2009 02:42 AM |
| lm4702 with complementry mosfet output | steven344 | Chip Amps | 3 | 1st July 2008 11:07 AM |
| LM4702:increase the output current,possible?? | Leolabs | Chip Amps | 3 | 14th January 2008 04:11 PM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| LM4702 triple darlington output | alexcd | Chip Amps | 24 | 16th June 2006 03:10 PM |
| Page generated in 0.19744 seconds (52.00% PHP - 48.00% MySQL) with 11 queries |
