| Chip Amps Amplifiers based on integrated circuits |
Dear friends,
I have some doubts about component characteristics, I have doubts in resistors R1 to R5 power, tolerance and type!! And for capacitors the same C1 to C7, type, tolerance, voltage, ... What is the maximum speaker power that I can use in the output (ohms and power)? And for end, What components I can remove from the original circuit? My very best thanks for all the group!! Alcuemar |
#2 |
Which schematic?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
The schematic showed in the first page from the LM1875 datasheet. Alcuemar |
#4 |
I'll tell you a big secret... You can use just about anything on these chips. Any little resistors, 1/4 or 1/2 watt, 5% or 10%, it really doesn't matter. It's low power, low voltage, just get as close to those values as you can.
Use caps rated higher then whatever voltage you're putting into the chip... don't overthink it! have fun and experiment... |
#5 |
Dear Alcuemar,
All resistors are 0.5/0.6W 1% metal film. C1 is an 50V elko, or a 63/100V foil cap. C2 is an 16V elko, or a 25V bipolar elko. C3 and C4 are 63/100V foil caps. C6 and C6 are 35V elkos. C5 is a 63/100V foil cap. Output pwr is about 25 Watts. What components to remove? Nothing. Build exactly the datasheet's circut. Best regards, |
#6 |
it is my understanding that this is a commercial project.
in anycase, use ohm's law and power law -- P = V^2 / R. keep in mind that to get 0.25W into a 1kOhm load you need approximately 16V across the resistor. for 10k resistors you would need 160V. so at the low voltages, it almost certain that you will have no issues with the large resistors. tolerance likewise is based upon the equations. the gain equation will show the maximum deviation of gain. this can be used for the left and right channel and you can find how much louder the "maximum gain" would be compared to the "minimum gain". where maximum and minimum are due to the component tolerances.
if only it could be used for good, not evil... |
#7 |
Why is the reason to put a 1ohm resistor (R5) and one cap 0.22uF (c5) in paralell with the output (speaker)? Anyone know it?
#8 |
The r/c on the output, is a low pass filter. It helps to keep load reactances and voice coil back-emf, from making the amplifier oscillate.
It's not whether you win or lose, it's how you lay the blame. |
#9 |
That'sa Boucherot-cell. Don't remove it!
#10 |
Thanks to all for the explication!!!!!!!!
| BILL and TILL | elnino86 | Parts | 0 | 14th December 2008 07:21 PM |
| Contacting Bill Christie | alpine67 | Everything Else | 0 | 29th May 2008 04:01 PM |
| How much is your electricity bill? | HeadSh0T | Pass Labs | 16 | 20th July 2003 07:23 PM |
| Page generated in 0.19452 seconds (43.36% PHP - 56.64% MySQL) with 10 queries |
