Old 22nd May 2006, 02:10 AM   #1
Default pa100 pcb single sided layout lm3886
here is a good layout for the lm3886 pa 100 watt ref schematic an-1192. has the following features. mute/ snubber network on output/ signal ground to power ground resistor. the 68 uf caps can be 22 uf to 68 depending on the high freq. rolloff you want.
for my application i am usig 22 uf. also the 1 uf on the input can be 1uf to 10 uf as this is used for decoupling the input as well as dc blocking. larger values will allow more bass to the input smaller more treble. amp is dead quiet, no noise a v +- 40 volts using my pwr supply listed elsewhere. the output resistors are .1 ohm 5 watt 1% silicon coated pwr resistors mouser# 588-45fr10e and they stand upright on the board. all others are 1/2 watt 1%metal film. the 20 k feedback resistors were matched with a meter so buy 20 pieces unless you go to .1 % for equill gain per chip.
Old 22nd May 2006, 02:11 AM   #2
Default comp side
here is the comp side
Old 22nd May 2006, 02:14 AM   #3
Default pa100 xray
here is the x ray of it looking down from the comp side. the bottom dimention is 116.00 mm or 116.00 divided by 25.4 to get inches.
Old 22nd May 2006, 05:44 AM   #4
Send a message via MSN to -_nando-_ Send a message via Skype™ to -_nando-_
Humm... I think the circuits are too tiny, don't forget that is a high power device. These tracks will not suport deliver 100W RMS of continuous power.
Common Ground is good to do, you can avoid some problems with this!
Check out my BPA200 Design. Not finishied yet, but you can follow the idea !
Common Ground Layout & Manual Work !
Old 22nd May 2006, 05:18 PM   #5
Definitively people don't want to answer LM3886s PCBs posts heh !
No answer in my post, and just me answering yours... Of course, there's lots of pcbs, just use search engine heh... Just a bit sad with the situation, but it's ok...
Old 23rd May 2006, 12:44 AM   #6
Default pa 100
Big misconception about the trace sizes, youres are fine. A standard mil trace at a average width of 1/4 inch can carry over 15 amps up to 2 inches give or take a little
Old 24th May 2006, 01:45 AM   #7
Default TRACE SIZE
I ALSO LAY A BIG BUILD UP OF SOLDER ON THE LOAD CARRYING TRACES TO HANDLE THE CURRENT WORKS FINE THIS IS DONE ALOT IN MACHINERY PCB'S I WORK ON AT WORK. THE WIRES ON THE BOTTOM SIDE IS FOR THE MUTE FUNCTION FORGOT TO INCLUDE IT SO I POINT TO POINT WIRED IT. THE PCB ABOVE IS CORRECT
My tiny single sided LM3886 PCB layout. :) Russ White Chip Amps 74 14th September 2008 06:53 PM
Parallel LM3886 Chipamp layout (PA100) zei Chip Amps 6 11th September 2008 12:12 PM
Wanted single sided PCB layout sivan_and Chip Amps 6 26th January 2006 10:36 PM
Page generated in 0.11741 seconds (57.03% PHP - 42.97% MySQL) with 11 queries
