Old 19th May 2006, 05:51 PM   #1
croat47 is offline croat47  United States
croat47's Avatar
Default SMPS Specs
Has anyone used something like this in GC designs? I read the Decibel Dungeon site about the Skynet modules. I am interested due to the comments about listening impressions.
Would a standard computer PSU be suitabile for use in a chipamp PSU?
The following is not as cost effective, but is designed, built, and I am not a PSU designer/builder. (looking at the audiosector kit).
http://newark.com/NewarkWebCommerce/...KU=83F2680&N=0
Also, it might allow a nice slim monoblock approach...sleek looking and all.
Regards.
Old 19th May 2006, 05:57 PM   #2
jackinnj's Avatar
if you want to purchase brand new switch mode power supply units check out Jameco --
Old 19th May 2006, 07:31 PM   #3
croat47's Avatar
The Jameco units are 24V and would be 70usd each for ~140usd plus shipping.
I can get 4 12V Skynet units for 70gbp (~130usd) with shipping, and they are known to sound good.
I think I'll go that route, but thanks for the lead on Jameco!
Regards.
Old 21st May 2006, 11:57 PM   #4
Default Hold on.
http://www.power-factor-1st.com/
These mean-well smps use rubycon capacitors, even lambda does not use them. I use 2 12v J60's for my gainclone, the sound is slightly dark, warm, detailed, with deep bass, totally quiet like my UCD180.... Priced way less than lamba in USA and, you don't have to wait for postage from motherland. And then, do the internal mods...
I have a lambda too, i think there is no difference between mean-well. I have not tried cpu smps, but i don't think they could be any better.
Strange enough, i like 12v to 24v, but Peter reassures me that the Lm3875 is underperforming at 12v. And those BG N100 capacitors do make an appreciable in refinement. Could try them with the money saved eh?
Chuck.
Old 22nd May 2006, 01:53 PM   #5
croat47's Avatar
Thanks for the lead. What about the S-150 line? 24V @ 6.5A. Two of those and I'm off to the races. Of course, I could start with one for savings...
But, with one set of speakers running 4ohms, will that be enough? Also, I need some help on the pin0out for these modules. It shows, G, V-, V-, V+, and V+. Does that mean there are two taps at the specified V and A ratings, or that the currrent gets cut in half by using both taps?
Thanks again.
Regards.
Old 22nd May 2006, 03:55 PM   #6
you need two to start. 24v S150 sounds like a good route. V-+G, on one side is for mains connection. The V+- on the other side will give you 24VDC. You need to connect one of the V+ and the V- of the other smps to give ground reference (pg+-,chg) to the amp. Then per normal, V+ on smps to V+ on amp and vice versa.
Attached a diagram from peter, for 24v, just imagine the use of 2 modules instead of 4. If you want actual pics like me know.
Chuck.
Old 22nd May 2006, 04:49 PM   #7
croat47's Avatar
Chuck,
Thanks! Makes sense. The S-150 units are available at TRC Electronics for ~45usd. I'd say that's my most economic option.
Now: about mounting. Do you heatsink them? Or just give them vent holes? And, any shielding other than the aluminum or steel case you might have?
Regards.
Old 22nd May 2006, 06:19 PM   #8
croat47's Avatar
Default Monoblock?
For aesthetic reasons, I would like to do a monoblock type of setup. How would a sinlge 24V unit be wired to a single audio channel.
Of course, the SMPS>cap>audio channel basic flow would be there. But, would the ground reference be the "V-" or the "G" terminal of the SMPS?
Regards.
Old 22nd May 2006, 09:27 PM   #9
Ground would be the combination of V- and V+ of two different smps outputs, i don't see anyway of using one smps without some serious modifications. Look at the diagrams for linear supplies to try and imagine.
These smps are slightly different from Nuuks, where there are ground pins to use.
Although i have successfully modded t-amps, chip amps and the ucd, i actually am pretty new to DIY (only a few months) and am an accountant by training. Learnt most of the my stuff by reading\asking silly questions and frying a few things here and there. I think hardcore diy'ers will cringe at the milieu of dead electronics i have caused.
If you want monoblocks on the cheap, buy some toroidals from apexjr.com. They are less than $20 each sans shipping.
The other way is that you have friends travelling to the far east. I got my lambda jws 150 for <$40 in singapore, when i was loitering back home. Occassionaly ebay might have blue light specials.
Hope this helps, i am sure others will weigh in.
Chuck
Old 22nd May 2006, 09:33 PM   #10
Originally posted by croat47
Chuck,
Regards.
I left them as they are - outboard. Was going for the fashionable neo-industrial look. I have an acrylic casing, so it matches somewhat. Braiding the wires gave a cleaner look.
ADC specs percy Digital Source 10 12th January 2008 02:18 PM
MS 5.30 Specs Inductor Multi-Way 0 4th September 2007 09:37 AM
need specs for amp hotdobbz Car Audio 1 18th February 2007 11:18 AM
Anyone Know what are the specs opf this amp? celeronkevin Class D 1 20th July 2006 02:03 AM
sub specs l2z2ama Subwoofers 2 13th November 2003 12:41 PM
Page generated in 0.26620 seconds (38.34% PHP - 61.66% MySQL) with 11 queries
