Old 17th May 2006, 05:21 AM   #1
zenon is offline zenon  Canada
Default Preamp specs for a chipamp
Will this work well as a premp for the chipamp kits?
Preamp Specs:
Output Impedance (Main-RCA)<600Ohms
Pre Out 1V
Maximum Output 6V
Volume Range (Main) -70dB to +10.0dB (.5dB resolution)
Old 17th May 2006, 05:29 AM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
You should not need a pre-amp for a chip amp. have you tried to run it passively with a pot in the middle ?
Old 17th May 2006, 05:40 AM   #3
I haven't built it yet.
I have a home theatre preamp in mind that I want to use with chipamp amplifiers so I just thought I would check into their compatability.
The idea is to have a mono chipamp run each stereo channel, and use stereo chipamps to run the rest of the HT channels. I was thinking that I may wire things such that for day-to-day listening I could use the HT preamp. Then maybe for more critical listening I could flip a switch that would make a direct path from the CD or such to the two monoblocks and use a resistor attenuator there.
Maybe I'm going the wrong way and should be asking the mfr???
What info should I provide them? Gain...... What else???
Old 18th May 2006, 07:22 AM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
In theory you shouldn't but in practice they sound better with an active pre, or buffer stage!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 19th May 2006, 11:05 PM   #5
phn is offline phn  Sweden
phn's Avatar
You need no gain. The CD/DVD player has all the output you need. Should be no problem running a chip amp with your processor, if I understand you correct.
And if I understand you correct again, you want to circumvent the processor when you listen to music. Then you need a volume pot somewhere between the CD/DVD player and chip amp. You could add a Buffer. Very minimalist.
Holler if I got you all wrong.
Old 19th May 2006, 11:09 PM   #6
Banned
I disagree. Adding a buffer adds more problems and more cap's resistors etc etc components. having a gain glone and a dvd/cdplayer with a nice passive pot. Will sound better.
Old 20th May 2006, 12:28 AM   #7
karma is offline karma  Canada
karma's Avatar
sometimes, i just finished peters output buffer and it sounds a lot better. mind you i made a few changes
only because i was in a hurry and blew it up the first time.
Old 20th May 2006, 06:41 AM   #8
I'm really liking that buffer! It gives me such deja-vu of the cmoy op-amp based headphone amp I'll be building soon. I think I'm already starting to formulate what I'll do!
-I think I'll make the same "typical rotary switch volume control" usually used
-except the lowest notch will connect the gainclone to the HT source (no attenuation)
-The next position would need to be disconnected?? (such that when you go from HT source to buffer source there's no signal mixing)
-The rest of the positions will be the same array of resistors usually found
Does THIS make any sense???
Just basically saying that you would turn volume all the way "quiet" to be @ HT source.. Two notches louder would be direct buffered source @ min volume.. and the remaining positions would be regular volume control.
Finally, What's a typical gain of these gainclones? I'll double check with the mfr that the preamp will work nicely with the typical gain used.
Old 20th May 2006, 10:53 AM   #9
phn's Avatar
I considered a similar setup once. I was thinking of using the Creative DDTS-100 surround decoder. But I would then only use a simple toggle switch to circumvent the decoder. As for your solution, use whatever makes sense to you.
I don't have a chip amp and am not sure about the gain. I would guess typical gain is around 26 db. Kore-eda chip amp
Old 20th May 2006, 11:59 AM   #10
Nuuk's Avatar
What about if you are running a NOS DAC with an inverted GC?
preamp for chipamp getafix Chip Amps 1 17th October 2007 10:49 AM
what preamp do you use with your chipamp? jarthel Chip Amps 5 26th June 2007 11:35 PM
chipamp passive preamp / crossover DoomPixie Chip Amps 4 23rd October 2006 09:13 PM
chip preamp for my chipamp? Russ White Chip Amps 3 9th March 2005 03:51 PM
Chipamp as preamp? lumanauw Chip Amps 24 13th May 2004 02:32 AM
Page generated in 0.15839 seconds (57.69% PHP - 42.31% MySQL) with 10 queries
