Old 17th May 2006, 04:53 AM   #1
Send a message via MSN to -_nando-_ Send a message via Skype™ to -_nando-_
Question Feedback resistor when using bridge mode
Hi everyone !
I read all the BPA200 datasheet, because I'm building it, and of course I know the manufacturer of the chip is right, BUT I DON'T understand why the feedback resistor (in red) is placed there !
The amp is used in inverse mode, so input signal enters in the inverse input, to have a inverse output to be connected to the -V of the speaker, and wow, you have the bridge!
The normal implementation (non inverted) use the feedback resistor to compensate the signal in, with the inverted signal, so, more feedback in the inverted input, less loud the sound will be...
So, WHY the inverted implementation don't use the feedback resistor connected to the non-inverted signal in? It don't make any sense to me...
Anybody ?!
Thanks !!
Old 17th May 2006, 05:29 AM   #2
rpapps is offline rpapps  Antarctica
Hi
The purpose of Rf & Ri in all four stages is to set the gain in accordance with the formula:
Vout/Vin = 1 + Rf/Ri
In this case, voltage gain is 22 or approximately 27 dB.
(Besides, if you connected the feedback to the non-inverting input you would have positive feedback, not negative. Oscillator anyone?)
Cheers
Rob
Old 17th May 2006, 05:59 AM   #3
Greg Erskine's Avatar
DELETED.
Sorry, I didn't read the post carefully and posted an inappropriate answer.
Greg Erskine
Old 17th May 2006, 06:22 AM   #4
Hi Greg, no need to apologise.
You were absolutely correct in what you said. I just used one formula to keep things simple. However, in practical terms, it makes less than a 1/2 dB difference which can be safely overlooked.
Cheers
Rob
Loudspeakers in Bridge Mode losaavedra Multi-Way 1 15th June 2009 09:36 AM
Difference between Bridge & Parallel mode john_lenfr Chip Amps 13 4th July 2005 01:27 PM
How to use STK459 in bridge mode tridibesh Solid State 0 4th June 2005 07:40 AM
Inverted gainclone with noninverted bridge mode akunec Chip Amps 0 20th October 2004 12:30 AM
bridge mode for LM 3875 partyjups Solid State 2 5th June 2001 05:49 PM
Page generated in 0.12506 seconds (48.47% PHP - 51.53% MySQL) with 11 queries
