Old 15th May 2006, 02:03 AM   #1
Default Is it a good idea to fuse secondaries?
Building a briangt chipamp with a 330v a toroid, posts in this forum advise a fuse on the primaries at something above the toroid rating, above the normal inrush current.
So a 4 amp fuse on a 330va toriod protects above 120v x 4 amp = 480 va.
Shouldnt there be protection for normal usage at or below the toroid rating, perhaps in the secondaries?
25 volt dc x 6 amps = 150 va. With 2 secondaries, each with a 6 amp fuse, total wattage allowed would be 300 watts on a 330 va toroid.
Is this a good idea?
Old 15th May 2006, 02:21 AM   #2
xplod1236's Avatar
Send a message via AIM to xplod1236
The inrush current is caused by the ps caps charging. So the inrush current will be present on both the primary and the secondary.
Old 15th May 2006, 02:22 AM   #3
put a fast blow fuse on each rail downstream to the filter caps.
Until you have the power supply debugged, put a slow blow fuse on each rail between the bridge and the filter caps. The fast blow fuses will help protect when you short your speaker wires. The slow blow fuses will protect from faults in the filter circuit.
Old 15th May 2006, 06:41 AM   #4
AndrewT is online now AndrewT  Scotland
balderdash.
Inrush current, for a toroid, is trying to establish the magnetic flux in the iron core.
Once the magnetic circuit is up and running, taking one to three cycles of the mains, then the caps can charge, but at a much smaller charging current.
So the recommendation for a T (delay) rated mains fuse and F (fast) rated secondary fuses AFTER the smoothing capacitors.
regards Andrew T.
Old 15th May 2006, 04:38 PM   #5
Default Where to place the fast blow fuses?
Seems to be some disagreements here, I'm siding with Andrew T's recommendation.
I have the 2 briangt 3875 amp boards in hand. and am trying to figure out where to wire the fuses in the circuit, and what amperage fast blow to use.
I am using an avel landsberg 330 mah 25v x 2 toroid.
Any advice?
Old 15th May 2006, 05:21 PM   #6
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Originally posted by AndrewT
Hi, balderdash.
As far as i know , it is important to keep both resistance and reactance low between supply caps and amplifier.For example, National recommends to use as short supply leads as possible.
Fuse can be not reliable here - oxidising contacts, etc.
To prevent it from accidentaly blowing due to current peaks , we would have to use higher amperage fuse. But then , what is the use of it ?
These are just my thoughts , i may be wrong.
Lukas.
Old 15th May 2006, 08:02 PM   #7
cpemma is offline cpemma  United Kingdom
Both my NAD and Rotel amps have pairs of fuses factory-fitted between secondaries & rectifier. 3A for the 25Wpc NAD (plus 1A on the preamp section's separate secondary), 5A on the 30Wpc Rotel.
Old 15th May 2006, 11:54 PM   #8
Default Should fuses be inserted between secondaries and rectifier pcb?
Has anyone inserted fuses between the secondaries and the rectifier board? Is this the way to go?
Old 16th May 2006, 12:56 AM   #9
put a slo-blo in series with the primary of the pwr xfmr
a fast-blo in series with the speaker ........ enough allready
Old 16th May 2006, 01:03 AM   #10
lndm is offline lndm  Australia
With some amps that have twin rail fuses, there can be the concern that if one rail fuse blows, the output may slam toward the other rail and your speaker may get a taste of DC.
So, any arrangement where all rails blow with one fuse sounds good to me.
Is this a good idea? Nolantor19 Multi-Way 3 12th August 2009 12:36 AM
Is this a good idea? AC439 Multi-Way 0 30th December 2008 07:48 PM
One transformer with 4 secondaries or two transformers with dual secondaries Baka Chip Amps 5 28th November 2008 06:39 AM
Seems a good Diy idea !! sivan_and Everything Else 1 12th November 2006 07:44 AM
is this a good idea??? dmh Solid State 16 24th February 2005 03:47 AM
Page generated in 0.15451 seconds (69.96% PHP - 30.04% MySQL) with 10 queries
