Old 14th May 2006, 09:38 AM   #1
Default how to make cheap amp
how can i make the possibly cheapest and simpliest amplifier im am only 13 years old and dont have a lot of money
Old 14th May 2006, 02:36 PM   #2
cpemma is offline cpemma  United Kingdom
Start with a kit version like this one but you'll find the power supply will cost more than the amplifiers. Or this TDA2005 stereo kit will run from a cheaper 12V power block adaptor.
Old 14th May 2006, 03:25 PM   #3
bob123 is offline bob123  United Kingdom
how much do you know about electronics??
Old 14th May 2006, 03:48 PM   #4
This would be your best bet. Components probaly cost about £5 but you would need something to build it on. I would recomend getting a breadboard and some singe core wire (£5).
The power supply would be the most costly part but using 12vdc adaptors that you can get quite cheap would be ok.
The sound quality from this simple amplfier is suprisingly good.
I think with a bit of scrounging it would be posible to build this for about £20 or maybe a bit less. It depends mainly on the power supply.
If you want to make this amplfier more powerfull you could get opamps that have max supply voltage of 22v and you could also bridge the amp into 4 ohms.
Doing this would make it run at about 200w for about 1 second (untill you get fireworks) provided that the power supply is sufficient.
P = (2 x 20 x 2/\-0.5)² / 4
If you dont understand the circuit diagram i suggest you read up on the internet:
OP-amps - Non inverting and inverting (negative feedback)
Transistors
Ohms Law
Good Luck!
Old 15th May 2006, 08:47 AM   #5
no iment like building from components buying them not kits because i cant buy kits here there very rare
Old 15th May 2006, 10:52 AM   #6
did you read my post?
Old 15th May 2006, 09:14 PM   #7
Send a message via MSN to -_nando-_ Send a message via Skype™ to -_nando-_
Heheheh !
TRY TDA2822
Tooooo simple, and you can power it from four (in the truth, from two to eight) Alcaline (or not eheheh) AA bateries !
And it is STEREO !
You can also try TA8238, plays well, and can be powered from a very cheap 12v supply!
You can find datasheets at www.datasheetcatalog.com
Datasheets contain all the information that you need ! Including the schematics, and some, the PCBs layout. If you don't find the PCB layout, use your creativity (it don't cost anything) and draw your own !
Oh, NO PCB!? Okay, turn on the PIG MODE and build it P2P HUAhuauAH! If you do it with a lot of care (and NOT running agaist the time), it will work, and the only cost that you will have will be the parts !
Old 15th May 2006, 10:54 PM   #8
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
I think the best for a beginner would be something like TDA2030 , TDA2050 , or better LM1875.They are easy to build , cheap , and have protection.
You will need dual power supply for these.
Powering from batteries is not the cheapest solution , because batteries need often replacement .
Lukas.
Old 16th May 2006, 09:51 AM   #9
thanks nando ill try it i found a place that sells pcbs 150 php per square inch thas that sound right and eches them for free
Old 16th May 2006, 05:06 PM   #10
sagarverma's Avatar
lm386
low power,1w ,less than $1, ..cheap,powered up by pencil cell.
construct on veroboard.time:<1 hour.
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Valves for sale - cheap, make an offer jack daniel Swap Meet 11 15th February 2005 11:11 AM
CHEAP speakers that will make me go deaf? mazeroth Multi-Way 17 27th July 2004 03:11 PM
Unemployed and Bored, what should I make for cheap? PHilgeman Parts 7 12th February 2004 04:17 AM
Ways to make a cheap computer sub less boomy? downhere Subwoofers 3 11th November 2001 06:25 AM
Page generated in 0.13957 seconds (56.43% PHP - 43.57% MySQL) with 11 queries
