Old 12th May 2006, 01:55 AM   #1
maxw is offline maxw  United Kingdom
maxw's Avatar
Default Simple gain question
Hey people,
I have a LM4780 amp with a gain of 33.5.
I want to decrease the output by 6dB.
This is where I get a little confused...
Does that mean I want a gain of 29.5? +6dB is like is like doubling the signal twice so I subtract 4..
Or does it mean I want a gain of 8.375, ie divide it by 4...
Or maybe I'm just completely wrong?!
Old 12th May 2006, 03:02 AM   #2
poobah is offline poobah  United States
poobah's Avatar
VOLTAGE gain in dB = 20 * LOG ( GAIN )
So you want to lose 6 dB... that's a minus 6 now.
Gain = 10 to the ( -6 /20 )...... (this is the inverse log)
Multiply that times your original 33.5 and you have it...
OR each -3 dB = 0.707
SO... -6 dB = 0.707 to the 2nd power ~= 0.5
Old 12th May 2006, 03:35 AM   #3
maxw's Avatar
Dang, that's complex!
So I subtract 0.5 from 33.5 to get my gain that achieves -6dB?
ie, 33.0?
Old 12th May 2006, 05:11 AM   #4
poobah's Avatar
Nope... you multiply the 0.5 times 33.5 to get a final desired gain of 16.75.
Here's the trick when you work with dB; you simply add or subtract gains. When you work with ratios... straight numbers, you multiply.
dB is a logarithmic way of workng with things. It got started long before we had calculators... the "Bell" in deciBell stands for Alexander Graham Bell. By working out dB charts for standard problems, math problems could be solved with simple addition and subtraction rather than mutliplication and division.
Strictly speaking, because of calculators, we don't need dB anymore. But it does make sense for alot of things and people are used to it. It works well for "signals" and radio... especially when long lines and distances are concerned.
Heck... for that matter it would have made more sense for our number system to be base 8 instead of base 10. People insisted that we got our thumbs into the act as well.
Here's the formula's:
Voltage Gain (in dB) = 20 * Log (output / input) & the reverse
output/input = 10 to the (gain in dB / 20)
Power Gain (in dB) = 10 * Log (output / input) & the reverse
output/input = 10 to the (gain in dB / 10)
"output/input" denotes "straight" mathematical gain.
Play with the numbers... 0 dB equals 1... 20 dB = 10... -20 dB = 1/10... it will make sense after awhile.
Old 12th May 2006, 05:53 AM   #5
maxw's Avatar
Excellent, thanks for taking the time Poobah, much appreciated
Old 12th May 2006, 06:28 AM   #6
preiter is offline preiter  United States
preiter's Avatar
dB represents a ratio between two things.
In this case, it's the ratio between the power that you have and the power that you want.
10 ^ (db / 20) = ratio that you want.
plugging in -6, you get...
10 ^ (-6 / 20) is about .5
so -6 dB means you want half as much gain as you have now.
Old 12th May 2006, 01:42 PM   #7
you are probably not aware there are hidden
dangers in reducing power amplifier gain.
A power amplifier has a gain margin, the gain margin (in dB) is
the ratio of the gain at which it oscillates to the gain it is used.
By reducing gain you are reducing the gain margin, making the
amplifier more likely to oscillate, e.g. instability during clipping.
Generally speaking to reduce gain you should attenuate the input.
/sreten.
Old 12th May 2006, 11:03 PM   #8
maxw's Avatar
yep yep, I know this.
From the LM4780 datasheet:
"Gain settings below 10 may experience instability.."
So a gain of 16 should be fine.
The reason I wanted it lower is because they will be powered by DRV134s, which add 6dB gain.
Old 12th May 2006, 11:05 PM   #9
poobah's Avatar
Good tip sreten and good work max! The data sheet is your friend.
Simple 12v gain stage dublin78 Solid State 10 14th April 2008 03:37 PM
Simple discrete unity gain buffer tcpip Solid State 111 7th June 2007 05:55 PM
Problems With Simple Gounded Cathode Gain Stage dr._sleep Tubes / Valves 4 23rd January 2006 08:31 PM
db, gain, and loudness. Simple math Pbassred Multi-Way 16 8th November 2005 03:13 PM
simple BJT gain stage hihopes Solid State 2 22nd September 2005 08:19 AM
Page generated in 0.10443 seconds (73.23% PHP - 26.77% MySQL) with 10 queries
