Old 7th March 2009, 05:30 PM   #981
a third one
Old 7th March 2009, 06:43 PM   #982
Pato666 is offline Pato666  Argentina
Send a message via MSN to Pato666
Default simply lovely
Very very very nice!
I like this design! thanks for sharing.
A word about me and my projects http://www.cristianortegadelrio.com [Brand new site!]
Old 7th March 2009, 09:48 PM   #983
raypalmer's Avatar
Very nice design mon ami. Much neater than mine! Is that 6mm aluminum plate?
Wherever you go there you are.
Old 8th March 2009, 04:58 AM   #984
Merci,
front al. plate is 4mm and rear is only 2mm, it will be replaced by a thicker one asap. Wood is from solid oak, and overall dimension are 19,6 (W)x 21 (L)x 10 (H).
Old 8th March 2009, 10:55 AM   #985
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
you could use some shielded wire for the connection from the pot to the amp and attach it to the wooden sides using some tape.The unshielded cable is most probably picking up hum from the trafo..the case is nice though very clean..
Old 8th March 2009, 11:06 AM   #986
AndrewT is online now AndrewT  Scotland
or move the pot to mount on the rear plate and use a shaft extender to connect the control knob to the remote pot.
regards Andrew T.
Old 8th March 2009, 04:20 PM   #987
audio1st's Avatar
Just finished fitting "Pedja's Discrete regulator" into my LM1875 Amp.. Had to end up using four, 25V, 30VA transformers because space was tight, (and I had them already ).
Loving the sound, a match made in heaven ..
Old 8th March 2009, 04:29 PM   #988
Great
What kind of speakers is it driving ?
Old 8th March 2009, 04:50 PM   #989
audio1st's Avatar
Originally posted by androuski
Great
MONITOR AUDIO GR10's
Specifications:
Drivers: One 1" Dome Tweeter, One 6 1/2" Mid-Bass Driver
MFR: 40 Hz - 30 kHz ± 3 dB
Nominal Impedance: 8 Ohms
Efficiency: 88 dB/W/M
Power Handling: 100 Watts RMS, 300 Watts Peak
Size: 14 3/4" H x 8 3/4" W x 11 1/2" D
Weight: 20 Pounds Each
File Type: jpg monitor-audio-gr-10-speakers-front-main.jpg (17.7 KB, 2017 views)
Old 8th March 2009, 06:37 PM   #990
Not such an efficiency ! Don't you feel any lack in the response ?
Page generated in 0.11749 seconds (61.55% PHP - 38.45% MySQL) with 11 queries
