Old 11th February 2009, 03:21 PM   #921
lanchile's Avatar
Thanks ide2003,I was looking for it too but,I did not find a "double pole" rotary switch (safer mode).I will keep looking.
Old 11th February 2009, 03:27 PM   #922
eboz is offline eboz  United States
Send a message via Yahoo to eboz
What do you switch if you go with double pole? Both neutral and hot?
BTW Mouser has some 6A rotary switches to use. SPDT or DPDT. I'm planning on using these for my next amp, not a chipamp though - Aleph 30 monoblocks.
Old 11th February 2009, 09:39 PM   #923
lanchile's Avatar
Yes eboz, I use one for the hot and one for the neutral.I am planning to get a rocket switch and put it where the green light is and the green light where the toggle switch is. http://www.parts-express.com/pe/show...number=060-310
Old 11th February 2009, 10:04 PM   #924
troystg is offline troystg  United States
troystg's Avatar
Put hazed plex behind the round hole and a LED behind it to light up the hazed plexi to signal when it is on.
So basically the hole would glow whatever color LED you have and be basic White when off.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 11th February 2009, 11:11 PM   #925
lanchile's Avatar
Good idea troystg!.I will start this week.I think I will use blue light better but,I do not want to use led(I do not want to disturb the power supply).so I guess I will put something like blue plexiglass.
Old 12th February 2009, 04:54 AM   #926
How would a LED disturb the power supply?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 12th February 2009, 12:24 PM   #927
troystg's Avatar
That's what I was thinking..
Troy
Old 12th February 2009, 05:18 PM   #928
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
a paralell design....blue ones panasonic audio grade caps , two FC 1000ufs , wima 2.5 mm polypropylene, tyco 0.1% resistors.
work in progress...
Old 12th February 2009, 05:20 PM   #929
another angle..boards a bit dirty after soldering though..haven't cleaned yet
Old 13th February 2009, 01:08 AM   #930
lanchile's Avatar
it will drop some voltage down.not too much but it will.
Copyright ©1999-2013 diyAudio
