Chip Amp Photo Gallery
Old 18th May 2008, 10:22 PM   #631
mekanoplastik is offline mekanoplastik
ps and transfo ready
Old 18th May 2008, 10:24 PM   #632
never mind the grounding ...i will fix it soon
Old 18th May 2008, 10:25 PM   #633
testing
Old 19th May 2008, 01:54 PM   #634
troystg is offline troystg  United States
troystg's Avatar
Originally posted by mekanoplastik
...i would apreciate some comments.....
A dab of heatsink grease since the chip is on a groove, and a washer to help spread the pressure of the screw holding the chip down.
Those are suggestions, not requirements.
I "personally" would have used different color wires for the ps to avoid potential confusion but then, some times I can be... well, you know.
Absolutely beautiful execution.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 19th May 2008, 01:59 PM   #635
Nordic is offline Nordic  South Africa
Nordic's Avatar
Beautiful implementation.... just keep the AC cord away from the signal wires...
Old 20th May 2008, 08:09 PM   #636
robertj88 is offline robertj88  Netherlands
Send a message via MSN to robertj88
Originally posted by bego2
My first working amplifier
gainclone lm3886
http://img.w3dizajn.net/viewer.php?f...0001902jkc.jpg
http://img.w3dizajn.net/images/P1000189teeq.jpg
i used the cheapest capacitors and the sound is beautiful...i`m 18. years old and i doesn`t have lots of money to buy a excellent parts.
Finally! There arenít only old man (and women?) here! Haha
Since I discovered this forum, Iím getting very interested in the whole DIY audio thing.
Iím 19 and just finished my first amp, it will suddenly not be my last.
specs:
Transformer: 500VA toroidal (22V-0V-22V)
Rectifier: 8 x MUR860 (with 100nF capacitors and heatsinks)
Buffer capacitors: 25mF per rail (50mF total)
Amplifier: 2 x Bridged LM3886 setup (BR100)
Will do an approximately 100W to 120W per channel at 8Ohm.
I can't say anything about the quality of the sound because I still havenít got good source/pre amp/speakers (any volunteers?).
All I can say the sound is very detailed, and it's _very_ powerful!
I really learned a lot of this project, for example that 200W is completely useless.
Normally I use 500mW and playing very loud maximum 10W, if I knew this I probably had build the single LM3886 setup.
Enough talking, here are the pictures:
Clickable
Clickable
Clickable
Clickable
Clickable
Clickable
Clickable
Clickable
Clickable
The back plate is cut with an CNC water jet (I only made the Autocad drawling), heat sink is done manually.
Now I'm gonna build a preamp in an identical housing only less high. It will have an embedded system (8051) and perhaps a DAC.
Thanks for making this possible for me, keep up the good work!
Founded feedback is always welcome...
Robert
Old 20th May 2008, 08:21 PM   #637
tubee is offline tubee  Netherlands
tubee's Avatar
Nice amp Robert!!
1 suggestion: try to get proper solid copper rails instead of the aluminium ones.
Daisy Bell
Old 20th May 2008, 10:34 PM   #638
john blackburn is offline john blackburn  United Kingdom
RobertJ88
I'm 47 and I've just finished my first amp, it's nowhere near as good as yours, beautiful work by any measure.
John
Old 21st May 2008, 04:32 PM   #639
Mr. Triatic is offline Mr. Triatic  Sweden
Mr. Triatic's Avatar
Another CMOY...
www.joddla.net/audio/
Old 21st May 2008, 05:17 PM   #640
luka is offline luka  Slovenia
luka's Avatar
Hi
Woow that is small, nice. Any other pic of it
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Chip Amp Photo GalleryHide this!Advertise here!
