| Chip Amps Amplifiers based on integrated circuits |
#501 |
Thank you.
I was asked to build a Patek integrated and this is how it came out. The volume control features a fixed series Vishay and switchable shunt Caddocks. I might build another one like that, but this time fully balanced with 4 gang switch for volume.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#502 |
Hi Peter,
Very... very.... nice Jopie |
#503 |
Well, what else do you expect from Peter?if it is from Peter,it has to be nice, no doubt!.
#504 |
Preamp IC: LME49810+LME49600
Poweramp IC: LME49810 Detailed information, recently released, please concerns. |
#505 |
Hi peter,
it looks like, although i can't be sure from the photo, that the input is going directly to the amp board rather than across the attenuator first. If this is the case, can you describe the configuration and why you chose to do it this way. thanks, Tim |
#506 |
Yes, indeed, that how it's wired.
I used fixed series Vishay S102 10k, mounted directly on amp board and switchable shunt Caddocks. It seems like the purest approach to volume adjustement. The amp's already making news: http://6moons.com/news/news.html
#507 |
If only that beauty were available in kit form
#508 |
OP: LME49710
Buffer:LME49600 |
#509 |
When do you think that preamp will be released? Looks nice and clean!
#510 |
I will be release DIP version(LME49710) of the preamplifier module. But the LME49600 have not formal release. So to have more time.
| Page generated in 0.10200 seconds (74.68% PHP - 25.32% MySQL) with 11 queries |
