Chip Amp Photo Gallery
Old 12th August 2007, 05:58 AM   #451
nycavsr2000 is offline nycavsr2000  United States
nycavsr2000's Avatar
KT,
Thanks. Lundahl amorphous core trannies in fact, add a little depth, are slightly more extended on the top end (without getting edgy) and give the low end a little "kick." They are pretty sonically transparent, and I definitely do prefer them in. I've had them set for 1:1 or 2:1, which gives me the full 30dB gain or steps it down to 24 dB gain. Galvanic isolation is just icing on the cake. The sound emanates from a spooky black background.
I first saw this used in Art Audio's Lissa. Thanks to Kevin Carter for helping out with this one.
Dave (planet10),
Thanks for the heads up. The pics show up fine for me, even on a different computer/server. I hope people just follow the link!
Best,
Anand.
Old 16th August 2007, 12:19 AM   #452
pinoy82 is offline pinoy82  United States
Thumbs up Gainclone Pointzero Kit Bridge 100W/CH
This is my second DIY Gainclone amp which run in bridge configuration, I bought the PCB boards only from Aaron who owns the EZamps website and I used Vishay/Dale metal film resistors, WIMA coupling caps, Panasonic FC electrolytic caps, OPA2134 OP Amp, OP07 OP Amp for servo. Dual Avel 160VA 22v transformer. I built a 50watt version of this kit but now prefer the 100 watt amp a lot of power. Listening impressions is very good even though this amp is not break in yet the details, imaging and clarity of this amp is amazing.
Jerry
Old 16th August 2007, 02:10 AM   #453
EnvisionAudio is offline EnvisionAudio  United States
EnvisionAudio's Avatar
Default Extremely Well Done
That even impresses me. Thank you for taking the time to build this amplifier the way you wanted it. You've taken the basic kit, which is good by itself, and made it fit for royalty.
Very well done, sir!
DCX2496/DEQ2496 Car Audio Conversions
www.envisionelec.net
Old 21st August 2007, 08:11 AM   #454
sukyone is offline sukyone  Thailand
sukyone's Avatar
Send a message via AIM to sukyone Send a message via MSN to sukyone Chip Amp Photo Gallery
Smile my lowcost LM3886 Amp
My Blog DIY By mr.SUKY.http://sukyone.blogspot.com
My Blog LED TV Buyer Guide.http://led-tv-buyer.weebly.com
Old 21st August 2007, 08:16 AM   #455
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The pictures would be coming out of your browser's local cache.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th August 2007, 04:30 PM   #456
Speedsmile is offline Speedsmile  Netherlands
Ok, as already mentioned in my thread about the CSS FR125S in aperiodic box, I build an accompanying amplifier for them from briangt lm3886 set.
I challenge everyone to build all 3 PCB's + toroid in a smaller package:.... I had a lot of fun (and stress ) trying to make the whole thing fit like that, there is really no inch left unused....
Contrary to what you would expect there is no humming/noise audible at all...
I did not really know what to expect from these, but I was pleasantly surprised, this small amp really plays on the same level (or higher) as the big Marantz below it.
Cooling is on the minimalist side, the heatsink gets about 50 degrees celcius. But considering the case of the amp below it already gets 50 degrees when used the whole day I don't consider this a problem...
The power led isn't visible when off, because the hole isn't drilled completely through the front panel. Gives a cool effect in real life, the photo's don't do it justice..
Old 25th August 2007, 10:54 PM   #457
troystg is offline troystg  United States
troystg's Avatar
"The power led isn't visible when off, because the hole isn't drilled completely through the front panel."
Is it Plexi or Lexan or something? It does look good.
Is the pwr switch upside down?
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 26th August 2007, 09:25 AM   #458
It is white plexi (acryl), I bought from an industrial plastic's warehouse nearby. It wasn't my initial intention to use this particular plastic, I have a laptop standard made of some VERY nice plastic. It has a soft feeling to it on top, and a whitish matte finish, but still kind of transparent. But at the warehouse they didn't know what it was so I had to settle for this stuff. Turned out rather nice, but I would have preferred the other material. I suspect that that is some normal transparent plexi, with some special surface treatment, something with steel whool maybe.
About the power switch: HAHA , so I did turn it the wrong way up after all, I tried to figure out what the normal way is, but looking at pictures from the Internet I couldn't figure it out...
Old 27th August 2007, 07:37 PM   #459
falcott is offline falcott
falcott's Avatar
Don't get too stressed. If you were living in this part of the world, the way you have fitted it is the correct way. It depends where you live as to whether OFF should up or down. Seriously.
"Everything should be made as simple as possible, but not simpler." - Einstein
Old 28th August 2007, 04:08 AM   #460
gmphadte is offline gmphadte  India
For a power switch position, there may be regional standards, but I install a power switch considering the easy way for the preferred condition and also decided by the safe position. Pushing up is difficult.
On the MIL spec oscilloscope TEK 465M, the power switch had to be pulled out for ON position
Gajanan phadte
Chip Amp Photo GalleryHide this!Advertise here!
