audio1st said:My LM1875 finished and boxed...
Front...
Another 1st master piece!
http://www.diyaudio.com/forums/showthread.php?s=&threadid=79303&perpage=25&pagenumber=31
Some pics...
http://i141.photobucket.com/albums/r42/Kooka1/GC003.jpg
http://i141.photobucket.com/albums/r42/Kooka1/GaincloneDM008.jpg
http://i141.photobucket.com/albums/r42/Kooka1/GaincloneDM005.jpg
http://i141.photobucket.com/albums/r42/Kooka1/GaincloneDM002.jpg
http://i141.photobucket.com/albums/r42/Kooka1/GaincloneDM001.jpg
Pato666 said:Kooka
That's an AWESOME job!
Congrats!
Thanks for sharing!
Thank you, Pato.
Added the brand in shiny gold
http://i141.photobucket.com/albums/r42/Kooka1/GC003-1.jpg
http://i141.photobucket.com/albums/r42/Kooka1/GC004.jpg
This is my new gainclone. Rather low diy-factor since I purchased most of the parts on ebay.
Chipamp kit with power supply - ebay
Loudspeaker protection (modded and used as buffer power on delay) - ebay
Softstart - ebay
Tube Buffer - ebay
Ground loop breaker circuit - diy
Case - diy
It sounds very good and soon I will try it with some higher class speakers.
The hum was terrible before I installed the ground loop breaker circuit. Now there is no hum at all.
Softstart - ebay
Tube Buffer - ebay
Case - diy
Thanks for your comments!
I think you should define it as a buffer since it's unity gain but i'm not sure about the definitions.
The corners are made from profiles I found in a pile of junk.
The buffer is a Musical Fidelity X-10D clone sold by diygene at ebay.
There will hopefully be two big analog vu-meters on the front but I have not yet found any proper ones.
FastEddy said:"Tube Buffer" ... That's a tube pre-amp, right?
Mighty mighty nice ...
verrry nice, h@kan
Have you seen these? (scroll down a little)
h@kan said:There will hopefully be two big analog vu-meters on the front but I have not yet found any proper ones.
pinkfloyd4ever said:
I dont find any vu-meters there.
Very nice ampere-meters thou.
Cheers H@kan
1875 chipamp strongbox
Just finished building the LM1875 kit form chipamp.com. Originally bought a 25-0-25 Toroidal, but decided that was way too large for what I wanted to do with this (ipod dock). I ended up using a Radia Shack 24ct .45amp which seems to work fine. The heatsink is small (salvaged from a dead computer power supply) so the thing gets a little warm but not too hot to hold.
It's my first gainclone. I definitely enjoyed building it and it sounds fine. I don't think I have the star grounding set up ideally (really only has a PSU star), but there's no hiss or hum and I'm quite content with it for now. My speakers are weak, so I don't think I can grade the sound quality until I fix that.
Anyway here are a few photos. The case was something my Dad probably picked up in the 40's, he kept papers in it and I think it goes a little beyond retro - maybe a pirate's amp.
Steve
arrrrghhhh!
Here are some photo's:
Steve
arrrrghhhh!
- Chip Amps
- Chip Amp Photo Gallery
