Chip Amp Photo Gallery
Old 22nd April 2007, 06:07 PM   #381
superhkm is offline superhkm  Norway
Originally posted by Mick_F
No primary fuse and no mains lead cleat. A potentially lethal combination.....
A good observation, take on of those big strips and wrap around the manis cable just on the inside of the cabinet/enclosure.
And those chips, do they not need heatsinking ?
Old 22nd April 2007, 06:43 PM   #382
frebar is offline frebar  Norway
I have a switch with remote control in the power outlet.
That one do have a main fuse.
You can`t see it on the picture.
But I will fasten the power cable better.
The chip have an internal cooling and don`t
really need one. It doesn`t get hot at all.
Old 11th May 2007, 11:13 AM   #383
kage is offline kage  Hong Kong
* so exciting to see this thread, doing the chicken dance*
Old 12th May 2007, 05:46 PM   #384
same is offline same  Italy
This is my version of tube buffered gainclone (3875 inverted configuration). PSU is separate from amplifier
Old 12th May 2007, 07:15 PM   #385
falcott is offline falcott
falcott's Avatar
I look forward to seeing some pics!
"Everything should be made as simple as possible, but not simpler." - Einstein
Old 12th May 2007, 07:27 PM   #386
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
frebar, why no heat sink ? YOU should put at least a piece of metal on there just incase they do get hot. Better safe than sorry with smoking woofers.
Old 20th May 2007, 02:35 PM   #387
69CamaroSS396 is offline 69CamaroSS396  United States
Default My First Chip Amp
Here is an amp I built for my son with his band's logo on the top panel. I used pcbs from chipamp.com. Purchased my own components otherwise. Very happy with the results. Will be used in an apartment system using some very nice Signet bookshelf speakers and a powered 8" sub. Strictly CD based with a decent player.
Custom paint was done by www.mccallcolors.com
Old 20th May 2007, 03:09 PM   #388
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Gorgeous paint job
Brian
Old 20th May 2007, 03:20 PM   #389
Thanks, I'm quite happy with it. The pictures don't really do justice to the depth and effect of the paint.
Old 27th May 2007, 07:55 PM   #390
kmj is offline kmj  Sweden
kmj's Avatar
my new and more compact amps. A pair of monoblocks with a opa549-chip in each along with a 120VA transformer running 33VDC, a few volts above recommended maximum but it seems to work.
.....Where the music comes to die.
Chip Amp Photo GalleryHide this!Advertise here!
