Chip Amp Photo Gallery
Old 11th February 2014, 04:20 PM   #2691
Joerytech is offline Joerytech  Netherlands
Originally Posted by regiregi22 View Post
Don't skimp on capacitance, it's pretty cheap these days.
This for sure is not the reason I did not add capacitance.
Its simply because the amp I've build has been tested with a lots of different capacitance and has been discussed a lots too and the conclusion from quiet a lots of people is that the setup like P. Daniel has made sounds the best.
I maybe will try to add more but until now I'm very satisfied with the setup.
Did you ever try your amp with the same capacitance I use now? who knows it may sound better.
FYI, I also use a 500VA transformer but for only 2 LM4780 chips.
Greetz
Old 12th February 2014, 06:41 PM   #2692
I've got a question.
At the moment I use Mission M52 speakers.
Some time ago I build different speakers:
Jack's Place - Vifa Basis 95 2.0
At that time I used hafler mono amps and it sounded great.
I wonder if the amp I build now (LM4780 parallel) will be able to drive them with satisfaction.
Old 13th February 2014, 10:11 AM   #2693
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Is there any reasonable explanation for why it may sound better with an small capacitance?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 13th February 2014, 10:36 AM   #2694
This is one link of many discussions about it.:
http://www.diyaudio.com/forums/chip-...tml#post581230
Old 13th February 2014, 01:43 PM   #2695
mrWagner is offline mrWagner  Hungary
This is still a pic gallery...
Old 13th February 2014, 04:09 PM   #2696
You are right, I'm sorry, if somebody still want to discuss the capacitance please open a new topic.
Old 13th February 2014, 06:59 PM   #2697
for continuing the capacitance discussion please go here: http://www.diyaudio.com/forums/chip-...ml#post3818465
Old 21st March 2014, 06:44 PM   #2698
Spuds is offline Spuds  South Africa
Old 22nd March 2014, 11:35 PM   #2699
idontknowjack is offline idontknowjack  Sweden
My first step into DIY audio! Finished it a few hours ago and I'm so pleased right now. It sounds great to me (and I have absolutely no good references before). I was worried about cooling not being enough, cooling grease running to the chip-pins, and noise from power supply, but there is pretty much no hum and it seems (so far) to be cool as well. Soo happy!!
Old 23rd March 2014, 12:11 AM   #2700
Bigun is offline Bigun  Canada
Bigun's Avatar
Looks good !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Chip Amp Photo GalleryHide this!Advertise here!
