Chip Amp Photo Gallery
Old 21st November 2013, 07:00 AM   #2581
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
Originally Posted by davym View Post
Post some then!
As Andrew T would no doubt say, safety first - second and last.
No idea what kind of footwear he favours Bob, but if I had to guess, I'd say safety boots
There,
Where is yours?
And yes, it is AGAIN a LME49811 and so on...
I am not going to answer any questions because of the contract reasons, so DO NOT ASK!
This design was sold.
Old 21st November 2013, 10:38 AM   #2582
bcmbob is offline bcmbob  United States
Nice looking amp, but if it's not DIY project oriented I don't understand the purpose of posting the photo. I say that not to be small minded, but it appears to be an interesting combination of through hole and SMD technologies.
Maybe you could post a non-commercial version and let us have at it. Looks like it could be fun to build and produce high quality stable sound.
Congrats on the sale. That's a dream scenario/result for most of us in this DIY community.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 21st November 2013, 12:27 PM   #2583
Closest match is this:
http://www.diyaudio.com/forums/solid...-lme49830.html
Although with the sister chip...
Untested board.
Discussion of similar implementations / suggestions of improvements in there please.
Old 21st November 2013, 12:48 PM   #2584
Bob M.
Old 21st November 2013, 02:09 PM   #2585
gadut is offline gadut  Indonesia
gadut's Avatar
I can't find CL60 here, while the softstart kit is so cheap $3 only, I like the design of utilizing 2 relays, I think it's for safety in case 1 relay is failed. I changed the relay to omron and elco to pan fc, others seem good. I count it gives start up delay around 2sec
Picture should be able to tell more than I can explain
ahh..just find out that I have not cleaned the pencil marking yet on heatsink
Old 21st November 2013, 03:28 PM   #2586
sextaafondo is offline sextaafondo  Argentina
Softstart circuits usually have 2 relays. One of them turns the whole thing ON connecting the load through NTC resistors, and after a short while (2-5 sec) the second relay bypasses them for a straight path.
Pablo
Old 22nd November 2013, 09:12 PM   #2587
davym is offline davym  Scotland
Here you go palstanturhin, since you asked!
My Ref FE's, just finished them. Shame i cant seem to use them with my DCB1 though, too much hum, not enough solutions.
Old 22nd November 2013, 10:00 PM   #2588
troystg is offline troystg  United States
troystg's Avatar
Very nice!!!
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 22nd November 2013, 10:05 PM   #2589
Thanks Troy!
They will be even better if I can track down the cause of that hum issue.
Old 22nd November 2013, 11:45 PM   #2590
udailey is offline udailey  United States
Passive Aggressive
Default Ok, I'll post some pics
I just finished a set of LM3886 amps. Not in a chassis yet.
They use LDRs as Ri and Rb at 1k and 680R. Input resistor to ground is a 22k Spicer wirewound.
Non-inverting.
Rf is a Vishay S102 at 20k. Caps are Nichicon FG and FW.
I fitted the delay circuit with the Zener at 14V and a 6k8 resistor from negative to mute pin.
Zobel is made of 4x higher value resistors. If there was any inductance in the resistors its now down by a lot. .1uf zobel cap is underneath and is just a good quality Epcos. I had one of those russian K73 or K75, forget which, but this sounds better.
LDRs are driven by LM334 and they get their regulated voltage via a 3k resistor to a 6v8 zener. LDRs have a small electrolytic and .1uf ceramic in parallel with their LED side.
I have to say I was completely blown away from the first few notes. This is the best sounding LM3886 I've built to date. I wish I could compare with my old MyREF but I sold it. I dont remember being this stunned by the MyREF though.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Chip Amp Photo GalleryHide this!Advertise here!
