Chip Amp Photo Gallery
Old 1st August 2013, 12:46 PM   #2461
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by Rainwulf View Post
Well done! You have some unshielded signal wires though, and they will pick up interference.
Where? I can see shielded signal cables there.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 1st August 2013, 12:55 PM   #2462
Rainwulf is offline Rainwulf  Australia
I was responding to dasazo sorry!
There is unshielded cables from his pot to the amp modules.
Old 1st August 2013, 01:05 PM   #2463
regiregi22's Avatar
Understood! Now, what could you propose as a solution if your grounding scheme doesn't account for a ground line from pot to boards? Maybe using shielded cable that is only tied to ground in the origin end?
Old 1st August 2013, 01:09 PM   #2464
i use shielded cable thats only grounded at the amp end, at the analog ground point.
Seems to work ok.
Old 1st August 2013, 04:06 PM   #2465
dasazo is offline dasazo
I used twisted cat5 for signal wiring and did not have any interferences. When I added second channel for input I had to use shielded cable as the cables running along induced crosstalk to each other. I have zero humm or interferences. In my opinion shielded cable is not needed if not routed near power wires or other input source.
Old 1st August 2013, 04:39 PM   #2466
mhouston is offline mhouston  Australia
mhouston's Avatar
I don't use shielded wire inside or outside amps etc. only from my MC stage to my RIAA stage which are both seperately. My wires\interconnects are either platted or twisted, never shielded.
Old 1st August 2013, 06:27 PM   #2467
Ulis is offline Ulis  Russian Federation
LT1122(buffer)+LM3886 (inverted)
Old 1st August 2013, 11:57 PM   #2468
35 volt caps? What rails are you running to the lm3886?
Nice circuit boards though!!
Old 2nd August 2013, 04:47 AM   #2469
tommy_o is offline tommy_o  United States
Sorry, I'm probably just dim, but where is the buffer on that PCB? Nice looking boards though. If you have a thread with other info, can you just link that so I dont pollute the photo gallery?
Cheers!
Old 2nd August 2013, 04:56 AM   #2470
benb is offline benb  United States
Cheers!
I'm guessing it's on the underside, maybe an soic 8. It'd be nice to see a pic from the other side as well as underneath, to see the speaker output connections and signal input connections. All I see is what appears to be power input on the left - everything else is covered up by arrays of big electrolytics!
Chip Amp Photo GalleryHide this!Advertise here!
