Chip Amp Photo Gallery - Page 245 - diyAudio
Old 6th July 2013, 01:31 AM   #2441
Originally Posted by SRMcGee View Post
Rainwulf:
I have been looking for something like those pins mounted on the inputs and outputs of the third photograph; what are they, and is there a corresponding female part?
Scott
In this case, they are just PCB pins, nothing special. They are just gold plated, and make it easier to solder wires too. I use them as anchors so that i can solder the thick wire to the actual PCB, the pins make the joint stable and stronger and helps prevent ripping the copper off of the PCB.
I dont think there is a corresponding female part.
I know what you are after though, you want "jumpers"
https://www.google.com.au/search?new...mg.cLxRrqjm6UE
Old 7th July 2013, 04:42 PM   #2442
ss007 is offline ss007  United States
Rainwulf:
Scott
Those gold pcb pins seem impossible to find in the US. I've bought them from Rod Elliott in Australia. If anyone knows of a US supplier please do tell!
Old 7th July 2013, 05:06 PM   #2443
bcmbob is offline bcmbob  United States
May be what you are after.
Ketstone Pin
Data Sheet.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 7th July 2013, 05:38 PM   #2444
Ketstone Pin
Data Sheet.
Thanks Bob!
Old 12th July 2013, 06:08 PM   #2445
apexaudio's Avatar
APEX TDA7293/4
Old 13th July 2013, 10:47 PM   #2446
gadut is offline gadut  Indonesia
gadut's Avatar
my_rev v1.3 without relay unit, half naked, maybe next week to complete the wood casing. it's just wonderful to hear it drives my floorstand
Old 15th July 2013, 06:45 PM   #2447
palstanturhin's Avatar
Default LME49811 + mosfets - again...
Old 15th July 2013, 08:20 PM   #2448
benb is offline benb  United States
What the heck is THAT doing in this thread? It looks WAY too professional! If only you could get that small heatsink with fins going "horizontally" so they would be vertical for edewise mounting like that. I presume the chip's power dissipated isn't so much as to need a critical/optimal heat sink design.
Old 15th July 2013, 11:40 PM   #2449
troystg is offline troystg  United States
troystg's Avatar
Beautiful!
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 16th July 2013, 02:22 AM   #2450
redjr is offline redjr  United States
Are those custom PCBs, or available commercially? Very professional build.
redjr
Copyright 1999-2017 diyAudio
