Chip Amp Photo Gallery
Old 8th December 2012, 12:38 PM   #2291
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by lanchile View Post
Connections from PG- and PG+ go to "power supply caps + and -"... that go to ground!
I am right here? let see the picture here:
Where did you get this wrongly drawn sch? I suggest you to remove it, as if build as shown if will probably make explode a 10.000uF capacitor, which is nothing fun for sure!
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 8th December 2012, 01:36 PM   #2292
R.I.P.
Reg,
which post and which schematic are you referring to?
regards Andrew T.
Old 8th December 2012, 01:39 PM   #2293
deadhead is offline deadhead  United Kingdom
Originally Posted by AndrewT View Post
Reg,
Post 2282 still being misquoted I think.
Old 9th December 2012, 02:58 PM   #2294
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
Don't know which one is called "audiosector" but the drawing in post #2282 is wrong.
Old 9th December 2012, 10:22 PM   #2295
Einric is offline Einric  United States
Einric's Avatar
The Audiosector P/S is in post #2283
Old 10th December 2012, 07:17 AM   #2296
dewets is offline dewets  South Africa
Guys!!!! THIS IS THE PHOTO GALLERY....
Please take your technical discusions to the appropriate sub-forum...
Old 10th December 2012, 09:25 AM   #2297
R.I.P.
safety issues over-rule all else.
regards Andrew T.
Old 11th December 2012, 10:10 PM   #2298
regiregi22's Avatar
Reg,
Post 2282. Look at the bottom half, positive side of the diode bridge is going to negative side of smooth cap. Negative side is connected to capacitor positive pole.
Safety first, sirs.
Old 11th December 2012, 10:22 PM   #2299
mhouston is offline mhouston  Australia
mhouston's Avatar
Looks wrong to me.
Old 15th December 2012, 07:55 AM   #2300
submaster is offline submaster
Default TDA 7293, my first amp
Case - steel, full hand made, front panel - aluminium 5mm, tda 7293
Chip Amp Photo GalleryHide this!Advertise here!
