| Chip Amps Amplifiers based on integrated circuits |
#221 |
The more power supply cacacitance and filteration, the better the sound.
If 1000 uF makes it better, then 10,000 uF will make it better as well. My little 150 Watt (x 2) amp has 40,000 uF on each of the rails = and it helps. http://3dotaudio.com/ampics.html These newer Class-D amps will also need plenty of power supply capacitance and filtration: http://www.diyaudio.com/forums/showt...20#post1072820 |
#222 |
Oh yes, now I got it: that's the idea behind my adding 2 10.000uF Rubycon caps on eachone of my supply units. Since I installed them later (I did not have a lot of room in the case, at that point, but ok...) I could notice the difference: muuuuch better with the 2 extra black cilinders!
#223 | |
yeah, most except Gaincards... |
#224 | |
#225 |
My attempt at a compact Bridged LM4780 Stereo amplifier in an old die-cast box, 220mm x 145mm (190mm including heatsinks) x 50mm high.
Made mostly from junk I had lying around. Home made single sided PCB,s The transformer is Mu-Metal shielded 4x 4,700uf/50v capacitors + 4x 1000uf/63v caps on PCB (one under each board) DC protection circuit and relay at rear + Speaker fuses 65 + 65w RMS 8 ohm 85 + 85w RMS 4 ohm 130w RMS one channel driven for 1min test. Given the transformer is so close I was surprised there is no hum and despite not using hi-end components (would not fit) the sound quality is still very pleasing. |
#226 |
" ... Given the transformer is so close I was surprised there is no hum ..."
'Cause the transformer is enclosed in a metal case of its own ?? = a quality shield close to the windings = ![]() As long as the mu-metal transformer case remains grounded to the chassis = very little hum. Q&A: how did you fasted the heat sinks to the case? ... and do the heat sinks ever get warm ?? |
#227 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#228 | |
Ok, but my boards sound better with the extra capacitors. I am almost new to GC, but my ears are still good, and have done a long career...
#229 |
The Heatsinks are attached with 6x screws into taped threads in the case and a strip of copper buss-bar helps spread the heat from the chip.
There is about 5w at idle so the heatsinks are just warm but get quite warm almost hot on hot days when the amp is pushed hard for long periods even into 8 ohm, I think the amplifier would over heat under the same conditions into 4 ohm. PS rail voltages are +/-42v, I would have liked it a bit lower but I have 12 of these transformers from old computer terminals and wanted to use one. |
#230 |
Should I put these in my next GC?
Came from a bit of telecom equipment I recently trashed (also had in it 12x 47,000/50v capacitors as well) |
