Old 4th December 2012, 12:19 PM   #2281
6L6 is offline 6L6  United States
6L6's Avatar
PG+ and PG- are connected at the amp PCB. It's how the circuit board is designed.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 4th December 2012, 11:56 PM   #2282
lanchile's Avatar
Connections from PG- and PG+ go to "power supply caps + and -"... that go to ground!
I am right here? let see the picture here:
Old 5th December 2012, 12:14 AM   #2283
Einric is offline Einric  United States
Default P/S & Amp Schematics
Here are the schematics for the P/S and the Amp.
Hopefully this sheds a little light on the subject.
Old 5th December 2012, 12:19 AM   #2284
The difference in the two power supplies is that the Audiosector P/S has reversed diode polarity on the AC1 in relation to the AC2.
Old 5th December 2012, 12:22 AM   #2285
6L6's Avatar
Electrically they are the same. The Audiosector schematic is drawn a bit non-standard.
Pass F4
Old 5th December 2012, 03:04 AM   #2286
Default lm1875 "Unyil"
My LM1875 Amp with simple PSU
Old 5th December 2012, 03:57 AM   #2287
benb is offline benb  United States
Look carefully at thr bridges in #2282 - the lower bridge will charge the lower electrolytic with the WRONG polarity.
Is there a policy here about non-photographic discussions in this thread? Should someone start another thread?
Old 5th December 2012, 04:33 AM   #2288
@ Dan where are your little chips hiding?
Old 5th December 2012, 05:09 AM   #2289
6L6's Avatar
Yes, you are absolutely correct! Good catch!
Pass F4
Old 5th December 2012, 04:33 PM   #2290
The Audiosector schematic is correct.
The +ve of the smoothing capacitor in both the upper and the lower halves is connected to the +ve of the bridge rectifier.
Copyright ©1999-2013 diyAudio
