Chip Amp Photo Gallery
Old 10th November 2012, 06:14 PM   #2251
Pato666 is offline Pato666  Argentina
Send a message via MSN to Pato666
@zimmer64 I love your work!
Very good man!
Old 10th November 2012, 06:25 PM   #2252
bcmbob is offline bcmbob  United States
Very nice build !! I don't see a mains fuse. Is there one in the AC inlet?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 10th November 2012, 06:48 PM   #2253
zimmer64 is offline zimmer64  Switzerland
zimmer64's Avatar
Yes, they are. But I struggle a bit with them. They continue to blow, when i switch the amp on. I guess the two 400va toroids use a lot of current initially. Even 6A fuses blow. I currently jumped the fuses...... Once switched on, all is fine. All voltages ae fine and everything stays cool.
I am looking for a soft start circuit as we speak, as i do not want to operate without fuses in the long run....
Old 10th November 2012, 07:06 PM   #2254
I bought this one and it handles two 200 VA and one 50 VA toroids with ease.
Bob M.
Old 10th November 2012, 09:43 PM   #2255
mhouston is offline mhouston  Australia
mhouston's Avatar
@zimmer64: Good build and you have followed the Gainclone formular very strictly. A lot of builders want to put in huge piles of filter caps. And very good to see you didn't use shielded wire. It just isn't necessary and dulls the sound.
Neat job. I have had mine in my main system for about three weeks now and are really enjoying it.
Old 10th November 2012, 09:54 PM   #2256
lanchile is offline lanchile  United States
lanchile's Avatar
Originally Posted by zimmer64 View Post
Here is my Chipamp. I started off with Peter Daniels LM3875 premium kit. I added a rack mountable chassis, large 0,7c/w heat sinks, EMI filter, Neutrik RCA's, binding posts, 400va 24v toroids.
Low DC offset of 8 and 16mv, no hum, the amp is quiet and stays cool.
Sound is very good, detailed, open. Good bass too.
Since I am not an engineer (just a middle aged newbie hobbyist ), I am very happy with the result.
Michael
My Project page
Change those small values power supply caps(10uf) Those are jokes for a power supply I would Use 6800uf or 10000uf at least per rail
Old 10th November 2012, 10:04 PM   #2257
mhouston's Avatar
This moves away from the Gainclone formula. It is believed that the small, generally 1500uf caps at the chip, caps provide better mid-range than huge amounts of filtering and storage. I use 4.7uf polies across my rec. bridge.
Old 10th November 2012, 10:24 PM   #2258
What if you use 4 or 5 or more 2200uF? that's better than one huge 10.000uF and works well for low range, I think.
Just asking.
Regards.
Old 11th November 2012, 12:09 AM   #2259
lanchile's Avatar
Just asking.
Regards.
That is right! but these people "THINK" they will get better sound with those 10uf as power supply. I guess they use them because they "saw" it in other gainclones amps. My first diy amp was one from Peter Daniel LM3875 and it came with those "jokes" 10uf caps as power supply. I try many values from 10uf to 40000uf, at the end I kept it at 20000uf per rail, I could feel the bass!!! and if people say they will loose mid-range...That is not true!
Real amps use ...real power supplies!!! you will NEVER find a 4.7uf or 10uf cap as power supply in a Bryston, Krell, Adcom, Acurus, Marantz, Fisher, Onkyo etc, etc, etc...not even in a cheap Radio shack radio or amp lol...
Old 11th November 2012, 12:17 AM   #2260
lanchile's Avatar
This is more like a real power supply for Gainclones!
Chip Amp Photo GalleryHide this!Advertise here!
