Chip Amp Photo Gallery - Page 223 - diyAudio
Old 24th October 2012, 12:55 AM   #2221
Lm1875 amp with 6ak5 buffer. Horrible wiring etc. but no issues with hum or noise. Sounds much more alive than non-buffered amp. Tempted to build another valve buffered chip amp with neater wiring. Transformer cover to be added for safety :-)
Old 24th October 2012, 12:57 AM   #2222
Does a nice job with efficient speakers. Probably 10W max output given low voltage rails.
Old 24th October 2012, 09:14 AM   #2223
mhouston's Avatar
Lodda loose wire.
Old 24th October 2012, 09:28 AM   #2224
Originally Posted by mhouston View Post
Lodda loose wire.
or expletive !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st November 2012, 11:10 PM   #2225
bcmbob is offline bcmbob  United States
Default What the H### is a BLAT ?
Here is a link to a fun project combining PC liquid cooling techniques and a small footprint power amp build. A bit of overkill for the LM3886 family but could easily be applied to high-temp situations.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 2nd November 2012, 03:15 PM   #2226
Liquid cooled build thread is up for those who may be interested.
Bob M.
Old 2nd November 2012, 03:20 PM   #2227
linuxworks's Avatar
chip-amps get hot enough to warrant liquid cooling? really??
My Photostream:http://www.flickr.com/photos/linux-works/
Old 2nd November 2012, 04:05 PM   #2228
No - Not actually, the idea crossed my mind several months ago when I was testing several standard convection heat sinks. Thought it would be good to introduce a control element. When the LM3886 gets close to the temperature protection trigger point the sound can deteriorate and intermittent drop outs occur.
In general the available SPL from the MyRef family is in the usable range with only an attenuation pot. As a big band fan/player, I push the amps (using 200 & 300 VA toriods in some builds) with a JC-2 pre and they stay in the upper range of the power scale when driving my fairly inefficient speakers. No doubt a larger heat sink could be sufficient, but that wouldn't be any fun.
I have said in several posts that this may well be overkill for a chipamp, but there is a possibility it might be a prety good fit for something like hotter transistor builds. I've seen some F5s and such the size of a small freezer There is also the possibility of hearing/measuring the performance of the LM3886 across it's working temp range. Not a super high priority but potentially interesting. I'll post anything of significance if I stumble across it.
Bob M.
Old 2nd November 2012, 04:48 PM   #2229
linuxworks's Avatar
don't you hear the pump, in a quiet room?
I can't have/tolerate any fans on, or inside my audio gear. my hafler dh500 sits unused since the damned thing needs a fan.
that's why I was surprised to see a noise-creator (lol, sorry) in your system, put there on purpose.
Old 2nd November 2012, 05:16 PM   #2230
Don't know if you have any experience with the liquid cooling for PC world, but they have developed some fantastically quiet pumps and fans. Once all the air has worked completely out of the system the pumps are dead silent. You have to touch them to make sure they are working. Fans are almost as good and any trace of noise beyond ~ 12" can be eliminated by slowing them down a bit.
The major cooling is not from fan air flow. All that is needed is a steady light breeze across the fins of the radiator. A little adjustment for efficient air and liquid flow rate (less is better) does the trick. There are also some good additives that both protect any metal components and increase heat transfer.
I guarantee you can build a liquid system all the way up to the 120mm format that you can't hear past 1 foot.
Bob M.
Copyright 1999-2017 diyAudio
