Old 1st May 2012, 06:20 PM   #2151
Nice work SoIL4x4. I assume the spring on the volume pot is used to adjust the resistance of the pot? Loving the clear lid, not sure how it would look if you lit the inside up.
Another project of mine: (a very big one at that!)
http://www.mp3car.com/vbulletin/show...5-pimping.html
Old 1st May 2012, 06:29 PM   #2152
Here is my latest amp. It's a little cMoy headphone amp built into an old iPod 40Gb case. I built it to run my new Sennheiser HD280 Pros. It runs on a single 9v battery, which can be charged via a DC jack on the bottom. The switch is for bass boost, the on/off switch is built into the volume pot. The OpAmp used is a Burr Brown OPA2132PA and I have set the gain of the system to 3.3
I used 2 SMT LEDs for the power light and charging light. These are soldered to a piece of strip board and glued to the case. In picture 2, you can see the blue LED shining through the iPod front. The charging LED is below this and is red.
Old 1st May 2012, 09:32 PM   #2153
SoIL4x4 is online now SoIL4x4  United States
Thanks, yes there is a spring on both sides. It helps with "feel" of the knob. Yeah I may leave well enough alone on this amp and plus I ordered a lighter note today so I have to prepare for a new project
I love how compact your amp is. It is a great use for all the broken ipods out there!!
Old 24th May 2012, 08:00 PM   #2154
Here is my latest little amp I built of some spare parts. It runs from 12 volts and the chip used is a TDA1519C. The sound is OK, nothing compared to my Gainclone or my headphone amp, but it'll do for the workshop...
The schematic used was the one straight out of the datasheet, nothing special apart from a 10 ohm resistor between signal ground and audio ground to help with ground loops etc.
Old 25th May 2012, 03:21 AM   #2155
Oery is offline Oery  Indonesia
Send a message via Yahoo to Oery
Originally Posted by SoIL4x4 View Post
Audiosector LM 4780 pcbs standard BOM parallel/dual mono configuration
Antek an-3222 toroidal transformers with antek covers
Nichicon gold tune 6800uf power supply caps, 13,600uf per rail
Clarity caps MSA 4.7uf input caps
amb e27 colume control pcb
alps rk27 potentiometer
Cardass ACBP binding posts
Cardass CTFA rca's
Schurter MSM 19LA power switch
8audio volume knob, refinished to match brushed aluminum
Heatsink USA 6" x 6" heatsinks
walnut side panels cut from May 8, 2009 inland hurricane storm wood, tung oil finish
2024 aluminum parts cut and finished using hand tools and a drill press
total weight @43 lbs
love it ! --- superb
Old 25th May 2012, 03:48 AM   #2156
La Mer is offline La Mer  China
This is mine. LM3886 Ref.E diagram, plus music fidelity A1 preamp. Finished in Jan. of 2011.
Old 28th May 2012, 02:28 AM   #2157
My project:
Old 1st June 2012, 02:21 PM   #2158
Pato666 is offline Pato666  Argentina
Send a message via MSN to Pato666
portreathbeach that's a sweet amp!!!
GREAT WORK!
A word about me and my projects http://www.cristianortegadelrio.com [Brand new site!]
Old 1st June 2012, 02:53 PM   #2159
bcmbob is online now bcmbob  United States
Marsvolta,
Your clean and minimal wiring really appeals to to me. Nice. Did you ever listen to the amps without a tube pre and if so what differences did you hear. Which one is that? Might be my next project - curiosity is getting the best of me.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 1st June 2012, 03:29 PM   #2160
Default GC LM3886
Another my GC LM3886 :
Copyright ©1999-2013 diyAudio
