| Chip Amps Amplifiers based on integrated circuits |
#2091 |
Very nice job whaleman ! I like those big input caps, I did it the same way but using Sonicap. I would use bigger caps for power supply at least 4.700uf 105c X 3 on each rail.
#2092 | |
Your LM3875 doesn't look anything like the one from Audio Sector and he is from Canada, not NJ. Are you sure you are quoting the right board from the right Vendor? Regards |
#2093 |
I think there is another guy on ebay with that name. I bought some 'cheap' PGA chips from an audiosector ebay seller and I'm pretty sure its not 'our' audiosector guy from canada (peter).
My Photostream:http://www.flickr.com/photos/linux-works/ |
#2094 | ||
Thanks, the case is from Par-Metal like someone said.
That heat sink I think came from an Onkyo receiver I junked for parts. Quote:
These boards were quite nice, gold plated I think. But not the same person. Last edited by whaleman; 20th February 2012 at 11:32 PM. |
#2095 | |
#2096 |
I thought so, but the finish looks so smooth.. the ones from P-M I have seen had a different finish (or so it seems from the photos).
Thanks! |
#2097 |
I actually take some 00 steel wool and rub the whole case (in the direction of the brushing), then I use Brasso on the front and back plates. Otherwise it is a bit rough.
#2098 |
Audiosector LM3875, Antek 300va 22v+22v transformer, Par-Metal 12x12x4" chassis.
It's built exactly like the schematic right now, The case is kinda big so I have room to play with PSU configurations. There is no doubt I need to get a prettier power switch... Initial impressions are very favorable! ![]() ![]() ![]() ![]() ![]() Once it's all done in it's final configuration I will do a build thread. |
#2099 |
Just got on to this forum and saw this - what a beautiful creation! The best I've seen so far.
#2100 | |
SPST Round Rocker Switch w/Red Illumination 125VAC 060-716 |
