Chip Amp Photo Gallery
Old 5th November 2006, 10:28 AM   #191
karma is offline karma  Canada
karma's Avatar
nice work.
cheers
http://www.karmaelectronics.org
Old 5th November 2006, 11:58 AM   #192
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default Re: caps on bridge
Originally posted by halo0925
.01uf to .1uf caps are often used on each diode to help damp out the switch on and off of the diode helping to reduce residual AC noise, and some what help its clamping.
Read this -- it works
http://www.hagtech.com/pdf/snubber.pdf
Old 5th November 2006, 06:10 PM   #193
jaudio is offline jaudio
Good work!
What's your next project, a preamp perhaps?
Old 5th November 2006, 06:24 PM   #194
gothmog42 is offline gothmog42  Germany
well,
for the moment im doing mainly digital stuff with microcontrollers and so...
but im planning to build a music-driven stroboscope for a party in two weeks...
when audio-related questions come up i will be here again...
so long!
jonas
Old 8th November 2006, 09:44 AM   #195
kmj is offline kmj  Sweden
kmj's Avatar
My latest contribution. A couple of things that I have spent the last month or two putting together for a friend (have taken my time at it) and have now got all flaws taken care of.
DC-offset can't be measured with my multimeter under normal use and with a pair of ZHorn Herukas (Fostex 168EZ-sigma) a light buzz is just noticeble at a range of a few centimeters so I am quite happy with it. Oh, It is a hardwired LM3875 Gainclone with dual transformers of 2x25V and approx 200VA each.
The preamp is a Freebird with one OPA134 per channel.
The CD is a Marantz CD-57 with some parts removed (thanks to the guys in the Marantz modificationthread!).
.....Where the music comes to die.
Old 8th November 2006, 09:46 AM   #196
kmj's Avatar
another one.
Old 8th November 2006, 03:45 PM   #197
FastEddy is offline FastEddy  United States
FastEddy's Avatar
kmj: We notice a Marantz CD player in your system. Wondering if you have considered any players that will playback DVD-A (DVD-Audio) &/or SACD ... ?
That's a really fine pre-amp & amp setup ... wondering also if you have any inside pics?
Old 8th November 2006, 03:59 PM   #198
kmj's Avatar
I have a pioneer PD-656 which plays SACD and DVDA but I rarelly use it. I have never gotten hooked on these things, I have some DVD-As but seldom even play them.
Ah, you want nudiepics?
Preamp
Old 8th November 2006, 04:03 PM   #199
kmj's Avatar
And the poweramp.
I had som buzzing in the beginning and tested to add aluminumfoil as isolation but the problem was ofcourse the grounding as usual ut since I glued it on it has to stay where it is.
It might look like a ratsnest but I swear that it is ok
And building the top and sides in one piece and the bottom, front and back in one makes it easy to fiddle around with
Oh, EDIT:
the sugarlumps (Eurosockets?) came with the broken amps a salvaged them from and since they where already there I didn't bother to remove them. Doing that might make the layout a bit nicer but since it works fine I'll leave it as it is.
Old 8th November 2006, 04:33 PM   #200
FastEddy's Avatar
" ... DC-offset can't be measured with my multimeter under normal use and with a pair of ZHorn Herukas (Fostex 168EZ-sigma) a light buzz is just noticeble at a range of a few centimeters so I am quite happy with it. ..."
I might suggest adding one or two plastic snubbing capacitors to the pre-amp power supply at the PS output rails ... 0.1 to 1.0 uF MKS type (sprague or other) should do it. Might knock that hum right off the lines. (This would work the same way as the mods you did to your Marantz CD player.)
Chip Amp Photo GalleryHide this!Advertise here!
