Chip Amp Photo Gallery
Old 22nd August 2011, 04:36 PM   #1881
dewets is offline dewets  South Africa
Just a quick reminder: This IS the photo gallery.
Let's take our non-photo discusssions somewhere else...
Old 25th August 2011, 05:52 PM   #1882
Howlindawg is offline Howlindawg  Ireland
Howlindawg's Avatar
Hi folks,
My first post on here (although long time lurker) and my first Amp build.
Dual Mono Power Amp with 300VA torroids
Audiosector LM3875
HiFi2000 enclosure with Onzow illuminated switches
And I'll offer a big "Thank You" to Peter Daniels for all his help via email while I was putting this together.
Old 25th August 2011, 09:42 PM   #1883
imfree707 is offline imfree707  United States
imfree707's Avatar
Send a message via Yahoo to imfree707
Default Wow!!!
Originally Posted by Howlindawg View Post
Hi folks,
Audiosector LM3875
WOW!!!, great quality construction!
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
Old 25th August 2011, 10:00 PM   #1884
imfree707's Avatar
Default Stable 10 Watt Amp
Here's that 10 Watt 2 X TDA2003 Amp I built for my record player project. Proper ground wiring resulted in an amp that was completely stable under all conditions of my usage!
Old 25th August 2011, 11:46 PM   #1885
linuxworks is offline linuxworks  United States
linuxworks's Avatar
Hi folks,
"shorted turn" alert!
google that concept and remove that yellow wire. that's not a place to tap into chassis!
My Photostream:http://www.flickr.com/photos/linux-works/
Old 26th August 2011, 11:13 AM   #1886
Howlindawg's Avatar
No need for Google. There's no complete circuit around the core of the transformer and hence no shorted turn.
I do take the point that there's no need to earth at that point though.
It was just a handy spot to use during the build and testing when parts were being moved around. I have a much more appropriate and neater location for that chassis connection in mind.
Old 26th August 2011, 02:38 PM   #1887
linuxworks's Avatar
if you are deriving ground from the mounting bolt on top, it is a shorted turn.
it may not be as very bad one but it still meets the def, I think.
just wanted to point it out. other than that, I like the layout a lot.
Old 26th August 2011, 02:41 PM   #1888
digits is offline digits
digits's Avatar
I'd also remove them, or if you insist, run them from undeneath the tranny, so it doesn't make a loop around the core.
Beautifull work b.t.w.
Old 26th August 2011, 03:24 PM   #1889
bcmbob is offline bcmbob  United States
Hi Howlindawg,
I like your AC in cable. What is it and who is the source?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 26th August 2011, 03:34 PM   #1890
Howlindawg's Avatar
Originally Posted by bcmbob View Post
Hi Howlindawg,
Hi Bob,
The mains cable is Mark Grant DSP 2.5.
Three core 2.5 double shielded mains cable.
>Website<
Chip Amp Photo GalleryHide this!Advertise here!
