Chip Amp Photo Gallery - Page 188 - diyAudio
Old 11th August 2011, 03:48 AM   #1871
Pato666 is offline Pato666  Argentina
Send a message via MSN to Pato666
Originally Posted by discrete View Post
A PC heat sink without a fan is less efficient than just a 8"x4" square of heavy gauge aluminum plate.
The fins are too dense to allow for efficient convection.
The sink should also be turned 90 degrees so that the fins are vertical to have any hope of convection...
I didn't know that.. thanks!
Old 11th August 2011, 11:32 AM   #1872
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh
Ya definatly, i'll be used cooling fan also once installed in PC cabinet
The heatsink is meant for force cooling.
My Blog
Old 20th August 2011, 07:18 PM   #1873
(I don't want to hijack the picture thread, but my question is hardly worth starting a new thread for.)
How much heatsinking does LM3886 actually need? I've just received a pair of LM3886 kits from Analog Metric Limited - DIY Audio Kit & am thinking about enclosures for them. Do they actually need heatsinks, or can I just bolt them to a suitably thick metal enclosure? The amp in this auction simply bolts them to a (thin) steel enclosure ;
NE5532 + LM3886 Audio Amplifier Home Audio AMP 68W+68W | eBay
Old 20th August 2011, 07:30 PM   #1874
digits's Avatar
1C/W or less
Old 20th August 2011, 07:36 PM   #1875
Tripmaster's Avatar
Do a little searching and you will be rewarded.
Old 21st August 2011, 09:24 AM   #1876
frank1 is offline frank1  United Kingdom
Steel is an extremely poor conductor of heat so the poor chips would have virtually no heat-sink at all!
Frank
Old 21st August 2011, 09:27 AM   #1877
jemraid is offline jemraid  United Kingdom
Scrap yards are a good source of heatsinks and enclosures, take a pic of one with you. They'll sell them to you at weight value, they might add a bit though :-)
FH3 build using very simple tools and a point to point Gain Clone with largish power supply. http://www.jasread.com/fh3/index.html
Old 21st August 2011, 12:15 PM   #1878
I've got no problems with sourcing heatsinks, I'm just trying to ascertain how much heatsinking is actually required & how much I see in many of the builds is more just for show. I'm trying to keep my builds as simple as possible, so if I can get away with bolting the chips to a thicker enclosure rather than working heatsinks into the design, all the better!
How about a fairly thick aluminium enclosure? Something like Hammond's 1550Z Series? Hammond Mfg. - Watertight - Thick Wall - Diecast Aluminum (1550Z Series)
Old 21st August 2011, 01:24 PM   #1879
bcmbob is offline bcmbob  United States
lost eden -
I have no idea of your technical resources, but if you download the spec PDF (Data Sheet) of something like the LM3886 there are exact formulas and clear descriptions of heat sink requirements.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 22nd August 2011, 03:08 PM   #1880
troystg is offline troystg  United States
troystg's Avatar
Hardware stores usually have aluminum bars for sale. If you get a piece taller that the LM3886 chip and 4 times as wide, mount it inbetween the chip and the chassis, it will act as a heat "spreader" and move more heat to a wider area of a metal enclosure.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Copyright 1999-2017 diyAudio
