Chip Amp Photo Gallery - Page 183 - diyAudio
Old 16th June 2011, 08:42 PM   #1821
Pato666 is offline Pato666  Argentina
Send a message via MSN to Pato666
Originally Posted by regiregi22 View Post
There are always leftovers and spare parts, but you NEVER have spare transformers, big caps or heatsinks at least in my case.
ha ha ha, that's true!!! my case too
Old 17th June 2011, 02:57 AM   #1822
I have 5 transformers sitting in the corner
(not small ones either, big hefty 700va ones)
Old 17th June 2011, 01:20 PM   #1823
Default integrated GC lm3886 with OP2134
this is another GC..
Old 17th June 2011, 02:42 PM   #1824
mjf is offline mjf  Austria
lm1875........testing the "cheap amp" . playing music. it works.
Old 17th June 2011, 03:58 PM   #1825
tigersilver's Avatar
LM3886- 6 CHANEL
Old 17th June 2011, 05:00 PM   #1826
A heat sink is only a sink until it reaches the temperature of the heat source. It needs to exchange that heat with cooler air to continue functioning as a heat sink.
You will be better getting rid of those heat sinks and just bolting the chips directly to the chassis walls (assuming the walls are > 4 mm aluminium). This gives a chance for the heat to get out of the box and not cook your capacitor bank.
Even venting the chassis will not help, as the heat sinks are installed horizontally instead of vertically, thereby preventing natural convection.
Old 17th June 2011, 06:29 PM   #1827
udailey is offline udailey  United States
Agreed. Bolt to the side or put the sinks on the outside and drill some holes to mount chips on the sink. Even just mounted on the outside with no holes would help more.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 17th June 2011, 09:46 PM   #1828
linuxworks's Avatar
speaking of ventillation, is there any at the bottom? top is great, when you add it; but a lot of people don't add any on the bottom. air comes in from the bottom if you allow it..
My Photostream:http://www.flickr.com/photos/linux-works/
Old 18th June 2011, 02:04 PM   #1829
troystg is offline troystg  United States
troystg's Avatar
A couple of holes on the bottom in the back and a couple in the front on the top will give convection through this horizontal sinks and back to front cooling to keep the equipment rack cool.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 18th June 2011, 04:38 PM   #1830
linuxworks's Avatar
formulate_post("yo dawg", "heatsink on a heatsink");
(sorry)
Copyright 1999-2017 diyAudio
