| Chip Amps Amplifiers based on integrated circuits |
#1681 |
Hello,
the chassis you can get by elcal. www.elcal.de The knobs are "guitar knobs" , the are chrom, buyed on ebay. Regards Olaf |
#1682 |
Hello,
i have a question how to use a CL60 thermistor. Where must i put in the CL60, can someone help? Regards Olaf |
#1683 | |
In my build the tabs of the TDA2050's are insulated from the heatsinks. Cheers, BB |
#1684 |
This is my tda2050 stereo amp
![]() I like the sound and it has been working so fine since 3 months ago. |
#1685 |
Nice and small!
Where do you get the TDA2050 Kit? Olaf |
#1686 |
#1687 |
Depends on what you want the thermistor to do. If you want to use is as inrush current limiter, it goes in series with the transformer primary.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#1688 |
Hi;
This is my dual mono LM3875 chipamp. Thanks. |
#1689 |
this is my first chipamp(in serious mode) made with LM4766T, +- 25V DC, 3 Amp power supply. Please dont mind on the look. I am working to make it ugly to descent.
#1690 |
Just finished my headamp based on Texas Instruments TPA 6120. I'm quite happy with the design, the only thing I would suggest to the designer is to use 10M tantals in stabilizers ground path for better noise rejection and reverse diodes to protect the stabilizers. Since I didn't do any measuring, it is just my suggestion I don't know how much better the S/N would be. The sound is really nice, pure and clear.
