Chip Amp Photo Gallery
Old 1st December 2010, 07:47 PM   #1591
linuxworks is offline linuxworks  United States
linuxworks's Avatar
ouch!! stop, stop, make the bad voltage go away!
this is what happens when you 'do things' with voltage applied that really didn't need to have voltage applied. that's all I'm gonna say, too (lol).
that same day I was able to drive over to a local parts supplier (jameco), get the 3886 chip and since I had spare red-boards, I was back in business later that day.
the smell of silicon (in the morning) has not gone away, though...
My Photostream:http://www.flickr.com/photos/linux-works/
Old 1st December 2010, 10:00 PM   #1592
sandbasser is offline sandbasser  United States
sandbasser's Avatar
The smell of 'magic smoke' is never to be forgotten...
- Ray
Old 1st December 2010, 10:27 PM   #1593
linuxworks's Avatar
I found the 'eject smoke' pin but I can't say I'm better off for finding it
Old 3rd December 2010, 06:32 PM   #1594
st3al is offline st3al  Argentina
st3al's Avatar
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size. Click the image to open in full size.
Hello, This week i've been building that.
P88 Rod Elliot Preamplifier
2.1 Linkwitz-Riley 24db/oct crossover
TDA1557Q.
Regards.
Old 5th December 2010, 03:29 AM   #1595
linuxworks's Avatar
the gainclone is mostly finished now.
the VU meters are a stoopid frill found them cheap on ebay and they seem to 'bounce around' which is all I needed for this silly thing. I'll figure out some circuit for it later on. maybe.
audio wise, its sounding very nice indeed. changed some default R settings (lowered gain quite a lot) and the noise level is now on par with the rest of my system. quite nice.
Old 6th December 2010, 02:04 AM   #1596
st3al's Avatar
TDA1557Q.
Regards.
another try:
Old 6th December 2010, 02:24 AM   #1597
imfree707 is offline imfree707  United States
imfree707's Avatar
Send a message via Yahoo to imfree707
Default Meters
Analog meters can be tricky to deal with. They'll be really bouncy if the circuit does not provide meter damping. One can experiment with small electrolytics in the 1-47uf or so range to find a value that holds peaks for a second or two and install the correct value. Adding a cap will slow attack time if the driving circuit doesn't supply enough charge current for the cap.
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
Old 6th December 2010, 01:04 PM   #1598
linuxworks's Avatar
for the meter driver, I'm actually thinking (longer term) of a cpu-based solution. I do arduino programming and it might be possible to pull the spkr-out into the analog-in of the cpu, do the VU logic and log scaling there and then output a steady dc voltage for the benefit of the meter that way you can control the attack and decay and even peak-hold all in software.
Old 6th December 2010, 02:03 PM   #1599
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Even outputting it into a display
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 6th December 2010, 02:59 PM   #1600
imfree707's Avatar
Default Elegant!
With the pain in the a$$ that meter driver circuits can be, the digital approach is elegant.
Chip Amp Photo GalleryHide this!Advertise here!
