Chip Amp Photo Gallery - Page 139 - diyAudio
Old 4th April 2010, 06:15 PM   #1381
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh
@ Sharpi31
nice discrete buffer,
can you post some details of buffer. How about Power supply
My Blog
Old 4th April 2010, 09:32 PM   #1382
Thanks guys :-) copied ideas of others (mostly...).
The power supply is made of two 40VA 12Vac potted lighting transformers. The primaries of both and an additional earth wire are connected to the mains plug, and the secondaries and earth wire connect to the amp via a 3 pin XLR (earth plus one end of each secondary on pin 1, other ends of two secondaries on pins 2 & 3). The transformers were heading for the bin at work, and I thought I'd make use of them rather than see them wasted (I actually got three, and used the two with closest Vac on the seconadries).
The ebay fet buffer is discussed here: STEREO FET BUFFER on ebay
The big elna caps supply +/-17.5V to the LM3875 chips, which each have 2x 35V 470uF sikorel caps on the pins. The buffer gets about +/-17.2V from the four 220uF silmic II caps, that are supplied from the big elnas via a 22ohm resistor (each rail of each buffer channel is fed from it's own R & C).
The speaker terminals are from Maplin. I usually use speakons, but this amp is for test/play at work so screw terminals are handy.
Old 5th April 2010, 12:01 AM   #1383
troystg is offline troystg  United States
troystg's Avatar
It appears that you have input transformers AND DC input blocking caps..
(edit) That would be trafo and dc caps on the signal input path...
Is there a reason for both?
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 5th April 2010, 06:14 AM   #1384
The input transformers are there to isolate the amp from sources with noisy ground (laptops etc.). The output of the FET buffer has a small amount of dc offset, so the coupling caps prevent this reaching the LM3875 chips.
Not the last word in audiophile minimalism, but surprisingly good. I've built several chipamps and this one sounds most full and solid (the unbuffered ones sound thinner in comparison). The additional coupling cap is a small price to pay for having the buffer.
Old 5th April 2010, 02:20 PM   #1385
troystg's Avatar
Gotcha.
I would have expected a DC servo or offset adjust on the buffer to compensate but yes a cap is just as effective.
And I like the compactness.
Troy
Old 8th April 2010, 01:27 AM   #1386
Smile Mini Gain Clone LM4765
I got 2 LM4765 from NS 3 years ago. I destroyed one when I tried to
hardwire and stop it for a long time. I has been built this amp again
but used PCB instead of hardwire and succesfully to build 25Wx2 amp
from this IC.
I prefer its sound than LM4780 (60Wx2). Even if its power lower than
LM4780 but its sound is more smooth and clearly.
Old 12th April 2010, 07:56 AM   #1387
Originally Posted by okapi View Post
Hi, here are some photos of my audiosector LM4780 amps. I built monoblocks (1 lm470 in parallel) with separate power supplies so i could experiment with different configurations (biamp, bridge, use power supplies for other chip amps, power L, R, and surrounds, etc.)
EDIT - THESE IMAGES HAVE BEEN DE-LINKED DUE TO THE WEBSITE BEING REPORTED AS HOSTING MALWARE.
VIEW THESE IMAGES AND THIS WEBSITE AT YOUR OWN RISK. REMOVE THE XXXXX TO FIND THE CORRECT URL
http://www.tim.cheapo.ccXXXXX/images/SNB11160.JPG
http://tim.cheapo.ccXXXXX/images/SNB11022.JPG
http://tim.cheapo.ccXXXXX/images/SNB11127.JPG
http://tim.cheapo.ccXXXXX/images/SNB11121.JPG
http://tim.cheapo.ccXXXXX/images/SNB11132.JPG
http://tim.cheapo.ccXXXXX/images/SNB11133.JPG
http://tim.cheapo.ccXXXXX/images/SNB11136.JPG
http://tim.cheapo.ccXXXXX/images/SNB11143.JPG
http://tim.cheapo.ccXXXXX/images/SNB11155.JPG
http://tim.cheapo.ccXXXXX/images/SNB11151.JPG
i am presently designing a matching preamp that will look something like this:
http://www.tim.cheapo.ccXXXXX/images/preamp case.jpg
i would especially like to thank peter daniel for all his help, and Jim hahn for his guidance in the machine shop.
very nice work
Old 12th April 2010, 07:23 PM   #1388
I'll go better than "nice".
Beautiful. But then I'm not married.
Would any ladies care to comment?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th April 2010, 07:30 PM   #1389
troystg's Avatar
Stunning! Gorgeous!! Holy crap! Magnificent!
Cosmetically my favorite.
Troy
Old 13th April 2010, 09:51 AM   #1390
tangmonster's Avatar
That one was my favourite design also.
I liked it so much i based mine on it. Still not close too as cool as that one though.
http://sphotos.ak.fbcdn.net/photos-a...78216_6842.jpg
http://sphotos.ak.fbcdn.net/photos-a...78226_3200.jpg
http://sphotos.ak.fbcdn.net/photos-a...78228_3955.jpg
Copyright 1999-2017 diyAudio
