Old 18th January 2010, 09:34 AM   #1321
davidhugo's Avatar
Hi There
Your amp looks great. I am glad it sounds good as well. May I ask you a couple of questions as I am about to construct a Peter Daniel chip amp.
The 2 black ceramic caps which I presume are there to cut down switching on clicks? What value and voltage have you used?
Secondly the red caps shown on underside of the rectifier board are they Snubbers? Again what value have you used?
I would greatly appreciate this info before I start I want to completely try to understand what I am doing.
Many Thanks
dh
Power corrupts but powerlessness destroys you absolutely.
Old 18th January 2010, 12:49 PM   #1322
udailey is offline udailey  United States
Passive Aggressive
DH
Who are you talking to?
I dont see black ceramics on any recent pics but caps under a rectifier board would be snubbers and most likely if red they are Wima film caps of .1uf.
Voltage for any caps should be a minimum of 25% higher than the max voltage they will see. DC voltage will be 1.4 times higher than the AC voltage from the transformers secondaries.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 18th January 2010, 05:14 PM   #1323
davidhugo's Avatar
Default Capacitor Questions
Originally Posted by lanchile View Post
Hello I just add more juice to my integrated chip-amp.I had two "extra" Mundorf caps. so Now it has 20000uf per channel.The sound is wonderful.
Hi There.
The 2 black Capacitors connected across the mains input terminal strips which I presume are there to cut down switching on clicks? What value and voltage have you used?
Many Thanks
dh
Old 18th January 2010, 05:16 PM   #1324
davidhugo's Avatar
Default Capacitor questions
Originally Posted by udailey View Post
DH
Hi I was trying to address lanchile;202963 but thanks for replying anyway
Uriah
Old 19th January 2010, 03:01 AM   #1325
Here is a little something I put together over the weekend - LM3886
Old 19th January 2010, 03:09 AM   #1326
troystg is offline troystg  United States
troystg's Avatar
Nice case. Where'd you get it?
Side note: The slots appear to be contradictory in the pictures unless the bottom and top slots are off set.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 19th January 2010, 03:48 AM   #1327
I bought the case (ATI-738U) from ATI Research back in 2007. It has been sitting on a shelf, so I decided to use it for this little weekend project.
The slot difference is an optical illusion. Top and bottom have center slots.
Old 19th January 2010, 04:00 AM   #1328
Here is a picture of my old LM3875TF amp I did back around 2006. Acrylic, aluminum with heat pipes.
Old 19th January 2010, 04:14 AM   #1329
MJL21193's Avatar
Originally Posted by Wardsweb View Post
...with heat pipes.
Nice work!
Those "heat pipes" are pieces of hot water radiators.
Cool none the less.
Old 19th January 2010, 04:46 AM   #1330
Originally Posted by MJL21193 View Post
Nice work!
Cool none the less.
I had no clue. I saw Peter Daniel use some years ago and liked the look. I got these off Ebay. The pig tweak add some bottom end to the music.
Copyright ©1999-2013 diyAudio
