Old 29th December 2009, 10:55 AM   #1301
why do you want to parallel a pair of 8ohm drivers to give a 4ohm load and then give yourself the difficulty of designing a current limited chipamp that can adequately drive that low impedance load?
Use two amplifiers, each designed to drive an 8ohm load and dedicate one amp to one driver.
Fit each driver to it's own separate volume inside your box (sealed or vented) and if one driver or amp goes faulty you can still reproduce live music, just not as loud.
Old 29th December 2009, 11:28 AM   #1302
Pato666 is offline Pato666  Argentina
Send a message via MSN to Pato666
Thanks AndrewT for helping me how to plan this amp. You have a good idea , in the case of two bridged amp, i think i'll have to move to LM3886 chipamp. Thanks a lot guys.
A word about me and my projects http://www.cristianortegadelrio.com [Brand new site!]
Old 30th December 2009, 04:51 PM   #1303
danmartin's Avatar
Default my first LM3886
Hi to everybody...
Here is my first LM3886 Chip Amp using PCBs Kit from: eBay Store - HiLife-store: DIY-Audio
Most part are recycled except for the input/output connectors,
The chassis was built in the steel plate of the 360 x 280 mm
The cover is from an old Video Cassette VHS Player
The power switch and AC Socket is from a died PC AXT power supply
The split/dual pot volume control & knob was the a cassette deck.
The power supply is a transformator 2x20V 5A.
The front plate is made a piece 5mm thick of aluminium and black anodize finish
I really had fun with the amp. The sound is clean and fast
Thank you to the diyAudio community for providing me information to build this project,
Happy new year everyone
Sorry, my english is not so good
Old 30th December 2009, 04:53 PM   #1304
danmartin's Avatar
Other views
Old 30th December 2009, 05:23 PM   #1305
Puffin is offline Puffin  United Kingdom
Originally Posted by danmartin View Post
Other views
Sounds bad then ?
Old 30th December 2009, 07:17 PM   #1306
wim is offline wim  Netherlands
Default my last little job
Nice work Danmartin.....
My last little job: Peter Daniel boards with LM3875TF.
Power supply 2 x 120 VA. In plastic box, not interesting to show.
Sounds great.
The little VU-meters (with backgroundlight) are used becouse i had them laying around and they are nice to see, but they are no big deal.
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn.
Old 30th December 2009, 07:59 PM   #1307
Very good danmartin! Muy bueno!
Thanks for sharing your work.
Old 31st December 2009, 02:40 AM   #1308
lanchile's Avatar
Default More juice to it!
Hello I just add more juice to my integrated chip-amp.I had two "extra" Mundorf caps. so Now it has 20000uf per channel.The sound is wonderful.
Old 31st December 2009, 02:42 AM   #1309
lanchile's Avatar
More pictures.
Old 31st December 2009, 02:51 AM   #1310
nice knobs!
Copyright ©1999-2013 diyAudio
