Chip Amp Photo Gallery - Page 121 - diyAudio
Old 10th August 2009, 04:12 PM   #1201
marckus is offline marckus  Romania
Yes,thanks...first time i tried etching whit the photo imprint method...it worked quite nice. Thanks again to BrianGT for the design.
Old 20th August 2009, 05:51 AM   #1202
osscar is offline osscar  Latvia
osscar's Avatar
Congratulations to all team of administration with successful forum upgrade!
Here are pictures of my latest DIY Project gainclone the G:
Back panel
Inside (diy heatsink from two old ones )
Ready for testing
During tests side by side with Leach SS
quick specs:
Two transformers 2x24VAC 100W (on caps - 34VDC);
Two bridges from 16 MUR820 ;
Four RIFA low ESR 15 000uf 40V;
p2p wiring;
LM3875TF non inverting circuit with zobel network (0,1uf + 10R);
Case from eBay;
diy 4mm aluminium chassis;
2 apem white 230V LED (flat type);
Key switch (mechanical child lock  );
Two silver G letters with Swarovski crystal
Amp sounds really nice and powerful in whole range (very detailed High and Mid range, also low end is good)-no doubt, but I still prefer my SS leach (of course is in different weight class )
I will try to measure amp parameters later.
So, next will be some tube project i hope...
Old 20th August 2009, 07:59 AM   #1203
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
osscar where did you get the led setup for the front panel ?
are they running off the mains ?
Old 20th August 2009, 08:08 AM   #1204
osscar's Avatar
http://www.apemswitches.be/1-26847-S...ails.php?id=80
Yes - AC 230V, parallel with primary windings.
here is closer look on front panel:
My DIY : http://www.tutribi.net
Old 27th August 2009, 04:47 AM   #1205
Here is my first ever DIY audio creation. PD LM3875 gainclone
Old 27th August 2009, 12:39 PM   #1206
karma is offline karma  Canada
karma's Avatar
nice
Old 28th August 2009, 04:37 AM   #1207
lanchile's Avatar
Well done, I like it!..
Are you using it for Headphone amp?
Because if you do.That is a lot power for it lol
Old 28th August 2009, 05:53 AM   #1208
headphone jack is just for show atm Managed to fail at planning that one quite right. It's just filling in the hole now while I figure out how to implement it. Just plan on running headphones occasionally.
Old 28th August 2009, 03:34 PM   #1209
lanchile's Avatar
Well you can use a toggle switch for on/off
Old 28th August 2009, 03:55 PM   #1210
Puffin is offline Puffin  United Kingdom
If you want to make a Headphone-Out use this. Simples
http://sound.westhost.com/project100.htm
Copyright 1999-2017 diyAudio
