| Chip Amps Amplifiers based on integrated circuits |
#1191 | |
If you are willing to buy from China (I can understand a South Korean not wanting to) I purchased mine from VT4C Studio. Good prices and very fast shipping. Martin |
#1192 |
chief ryan why not use your lm chips for front or stereo music then used transistor type circuits for backup subs
![]() Ive got bargain china mosfet amps, at raon ![]() Its very cheap but no warranty, i gamble the rest of my money for that old stock looking "no warranty" china mosfet amp. I tested it at home a poof, it drives my two 8inch subwoofer at exact driving volume i think. I go back to the store and i get all the remaining circuits "lolols" |
#1193 |
chief t68kv!!!! are you a mamber of pinoydvd??
![]() we'll you're right, heatsinks are a bit expensive here in manila, room temps are a little high also here, ![]() i'm pretty conternted with the result of my diy sub and amp ![]() here's the sub in action, http://www.youtube.com/watch?v=uN3WLpLiDuE i'll build another stereo lm3886 for my fronts, ![]() @ t68kv btw, in what store in raon did you bought your china mosfet amp?? fyi, i've found a store near ongpin that sell some scrap heatsinks for 200php they are pretty large but have some odd shapes, ![]() i'm also thingking about buying a surplus amp at pier,
#1194 |
May i ask you sir what's your room temperature at your hometown. thanks
One reason why ryan use fan, is because we could not find a better heatsink here unless ordered it online which will be better to buy a OLD model kenwood av receiver here, because of the price and the tax. 2nd is the room temperature, actually the one i posted uses smaller heatsink to what ryan posted but the same type "because i need the lm4780 to be compact. The circuit actually good when our room temp is at 29c below, but when it return to normal 32c up, you cannot use it at higher volume without the fan . Well, I live in New York! Here the temp in Summer is from 80/98 But, I do not see it how it will get hot unless I put it in the oven hehehehe There is always a DIY staff lol. You can build your own heat sink from copper or aluminum or you can visit a local electronic shop and ask for an used heat sink.
#1195 | |
"luck or extra cash"Heatsink on our local elecshop is very thin, usually good heatsink is also came from junk amplifiers, if your lucky enough to get some ![]() Still Fanless is better, no need for extra supply or regulator just to run the fans ![]() Well room temp affects greatly on the amplifier case. My kenwood AV R will get very hot at 32c up temperatures compare with 28c below temps. I might come to china for some cheap alum case haha
#1196 |
@ chief ryan
i bought it at electronics shop at left front of deeco "deeco near at alexan", check it out, last time i check it they don't have it on their display. But if you want just pm me, i used the two circuit while i never know where to use the one left hehe. Bass I Love You! is the one of the best test song to see subwoofer's maximum excursion. BTW, My clips on my 8inch sub. http://www.youtube.com/watch?v=5_6N6YnRIE0 |
#1197 |
Finaly finished my litle gain-clone project.It is a stereo setup with 1 lm3886 per chanel. My goal was to make it as small as possible and as simple as possible while having a built in transformer. The simple part i think i got right, beeing that i did not put in even a power switch
. The pcb-s for the project are based on the ones made by BrianGT(thank you). The case I built is 21 cm(W) x 16 cm( L) x 4.6 cm(H). Its made from aluminium. Regardind the sound....like all gain-clones I believe...excellent.
#1198 | |
#1199 | |
Thank you! Here are some pictures of the interior. The transformer is a bit on the small side (120VA) but it does it's job. The heat sink is kind of small...it does get quite hot when i turn up the volume ...about 60-70 degrese C , but the case takes away some of the heat. Considering that the lm3886 has thermal protection i'm not worried. The front part of the case is made from a piece of thin(but very nicely machined ) aluminium about 0.5 mm thick epoxied to another thicker piece of aluminium. I'm planning on adding a litle LED on the front somewhere, so i do not forget it turned on, and possibly a power switch. |
#1200 |
Passive Aggressive
Etched your own boards! Nice
![]() Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
