Chip Amp Photo Gallery
Old 19th July 2009, 06:00 PM   #1181
dudaindc is offline dudaindc  United States
dudaindc's Avatar
Default Re: Is it worth the wait?
Originally posted by mrsbadcrumble
Pleased as punch...
Very nice mrsbadcrumble!
I like the idea of using a cast aluminum enclosure with a thick front panel.
Cheers!
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 20th July 2009, 02:16 PM   #1182
huseying is offline huseying  Turkey
Send a message via MSN to huseying
Thanks Richard and all.
Upload your pictures to PhotoBucket and and add through the 'IMG' button. Kinda round the houses but now I know.
I hope it's worth the wait...
And with the top off...
Pleased as punch...
It's nice job mrsbadcrumble
you portioned power section from amp section,It's beneficial to prevent magnetic obstacles.
You'ýý can add capacitor to power board except others,which are on the amp board
Finally
your amp is being seen very nice
Old 20th July 2009, 03:21 PM   #1183
gychang is offline gychang  United States
mrsbadcrumble, where did u get the extension bars for the knobs?. I need web site in USA...
gychang
Old 20th July 2009, 06:40 PM   #1184
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Originally posted by troystg
If you use Microsoft XP OS on your PC there is a free group of add ons called "power toys" that do various things. One is "Image resizer". Right click the picture and resize. That simple.
http://www.microsoft.com/windowsxp/d...powertoys.mspx
I loaded Vista, went back to XP. I loaded Microsoft 7 beta, went back to XP... I know, I know, "it's Linux time" <wonder if MC Hammer is going to patent that one>..
Nice tip! That will come in quite handy. I've used Visualizer Photo Resize up until now.
Anyway...back to the photos!
Old 21st July 2009, 08:16 AM   #1185
mrsbadcrumble is offline mrsbadcrumble  United Kingdom
mrsbadcrumble's Avatar
gychang
I found sourcing the mechanical parts took a long time but was quite good fun. Some of the contributors to this forum have excellent websites and they put a lot of detailed about the electronics but forget the ‘nuts n bolts’ aspect leaving you with no option but to search the web.
Unfortunately the web is a word based search engine (at least as far as I know!) and you need to know the name of the ‘thing’ you are seeking. You should also be aware that identical products will have different names in different industries, and that’s before you take into account different countries!
The extension bars are made up from a Brass Coupler Ľ” and 6mm aluminium rod cut to length. What isn’t seen in the photo is that each extension bar passes through 6mm diameter bushes held in the front plate.
Brass Coupler - Made by Jackson Bros in the UK but I got them via ebay.co.uk from a seller called Mainline Electronics Ltd. They say they post worldwide...
http://cgi.ebay.co.uk/4636-Brass-Cou...3%3A1|294%3A30
Good Luck
Jeff
Old 24th July 2009, 05:57 PM   #1186
quadtech is offline quadtech  India
gychang, check out Radiodaze for the shaft extension and couplers. Also
look for an idea I posted in this thread some time back.
http://www.radiodaze.com/potentiometers.htm
Old 27th July 2009, 02:45 PM   #1187
ryan750 is offline ryan750  Philippines
My Humble contribution..
two lm3886 for my DIY subwoofer powering each voice coil.
Old 27th July 2009, 05:05 PM   #1188
lanchile is offline lanchile  United States
lanchile's Avatar
Very nice ryan750! Do you really need those fun?. I ask you this question , because you can avoid any noises from fun just eliminatering them. in my case I do not use fun, instead I use a proper size heat sink (BIG) and it never gets hot and it is quiet as a mouse!
Old 28th July 2009, 03:04 AM   #1189
hi lanchile, thanks
couldn't get any better heatsinks because i'm on a very tight budget, btw, the fans are not that noisy, i can stand with them...
Old 29th July 2009, 04:30 PM   #1190
t68kv is offline t68kv  Philippines
@ryan750
chief ryan ok yan
@lanchile
May i ask you sir what's your room temperature at your hometown. thanks
One reason why ryan use fan, is because we could not find a better heatsink here unless ordered it online which will be better to buy a OLD model kenwood av receiver here, because of the price and the tax. 2nd is the room temperature, actually the one i posted uses smaller heatsink to what ryan posted but the same type "because i need the lm4780 to be compact. The circuit actually good when our room temp is at 29c below, but when it return to normal 32c up, you cannot use it at higher volume without the fan .
Anyway so much for that
Before i plan to buy a good case from china but because of tax here, i decided to buy a 2004 model kenwood av receiver which is more powerful and better in terms of sound quality.
Anyway more power to all chipamp users
Chip Amp Photo GalleryHide this!Advertise here!
