Chip Amp Photo Gallery
Old 25th March 2009, 12:55 AM   #1021
wirewiggler is offline wirewiggler  United States
Thanks,
The Base is metal and the chip-amps are insulated, no worries always good someone else is looking out for my health and welfare. It barely gets warm- Made mostly from scraps hence the utilitarian look.
Bill
Old 25th March 2009, 12:58 AM   #1022
troystg is offline troystg  United States
troystg's Avatar
Originally posted by wirewiggler
.....always good someone else is looking out for my health and welfare.
Bill
That's called the government...
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 26th March 2009, 02:56 AM   #1023
quadtech is offline quadtech  India
davidhugo
Another idea is to sacrifice a cheap donor pot. Open it up and
discard the shaft and other parts and just use the front mounting hardware.
Old 27th March 2009, 07:52 PM   #1024
davidhugo is offline davidhugo  Scotland
davidhugo's Avatar
RE:Another idea is to sacrifice a cheap donor pot. Open it up and
Nice to see some lateral thinking -it works- sheer genius. Thanks.
dh
Power corrupts but powerlessness destroys you absolutely.
Old 27th March 2009, 07:52 PM   #1025
davidhugo's Avatar
dh
Old 27th March 2009, 08:05 PM   #1026
troystg's Avatar
dh
I have to agree. A small sacrifice for a HUGE gain...
Jolly good thinking!
Troy
Old 1st April 2009, 03:51 AM   #1027
dh
Glad to know that worked. Do post a pic.
I'll try out my own idea soon for a MyRef amp I completed last weekend. ;-)
Another thing I found is that the brass insert from a 60 amp electrical
connector strip makes an excellent 6mm shaft coupler. Cheap
and easy to get anywhere!
http://www.reuk.co.uk/buy-60A-JUNCTION-BLOCK.htm
http://www.luxurylighting.co.uk/60-a...rip-2335-p.asp
Prasad
Old 1st April 2009, 04:04 AM   #1028
troystg's Avatar
Here in the US we have Home Depots and Lowes which are home improvement stores. I get some plastic spacer tubes for large screws / bolts and I use that for my shaft couplers as they are not conductive and isolate the shaft from the pot. Magnetic fields and static electricity are isolated from the pot itself.
But I always had the issue of the bushing in the front panel until quadtech posted that excellent idea.
Troy
Old 1st April 2009, 04:00 PM   #1029
FastEddy is offline FastEddy  United States
FastEddy's Avatar
" ... Another thing I found is that the brass insert from a 60 amp electrical
and easy to get anywhere! ..."
In Northern California, the Halted.com folks have lots of these for ~ US$1 each, for gangs of six to eight pairs. Surplus stock, but unused as far as I can tell. ( http://www.halted.com/commerce/catal...ACC39330A1A2A6 )
Old 2nd April 2009, 11:18 AM   #1030
Rainwulf is offline Rainwulf  Australia
5 channel LM3875 driving into 5 4ohm speakers, plus a 200 watt discrete block that drives the sub.
No input caps at all, film caps directly across the rails.
25-+ volt rails for the LM chips, and -+55 volts for the sub amp.
Chip Amp Photo GalleryHide this!Advertise here!
