| Chip Amps Amplifiers based on integrated circuits |
If I wish to put a GC Amp and a pre-amp in the same case, is it possible to use the same power supply to drive both?
Are there drawbacks to doing this? |
#2 |
Please search for your answer. This subject has been covered many times before!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
You can. See the LM317 and LM337 datasheets or do a search on this site. there are lots of schematics and even pcb layouts. Remember to use heatsinks.
The best would be to have seperate PSU's but for some it's overkill. That's what I'd like to do. PS LM317 and LM337 are better than LM78xx and LM79xx. |
#4 |
What is the PSU voltage in your GC at idle?
Mads K |
#5 |
Sorry. That could be a problem. You must look at the max voltage ratings for the voltage regulators. That's another reason LM317/337 is better than LM78xx/79xx.
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| Series power amps using a floating power supply | rtarbell | Solid State | 6 | 25th February 2006 08:18 PM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| Page generated in 0.09434 seconds (66.46% PHP - 33.54% MySQL) with 10 queries |
