| Chip Amps Amplifiers based on integrated circuits |
I purchased a basic briangt lm3875 kit last year and am just building it now. But I cant figure out how to build it because it didnt come with documentation and the current documentation on brians site, although for rev3, is different.
These boards (different layout) are marked LM3875 rev 3 with a date code of 0705. Where can I find instructions, a schematic, and /or a photo of these boards assembled? FOR THE AMP: I am guessing that I need to populate R1, R2, and R3, C1, C2, and the LM3875. I have C1, C2, and the LM3785s but dont have an R1 220 ohm resistor. But it does have 1K ohm low wattage resistors - could this be it? My kit has two 2.9 ohm higher wattage resistors - is this supposed to be for the Rf or Rz slot on the pcb? Is the Rf, Rz, and Cz slot unused? FOR THE RECTIFIER PCBs: Kit has the 8 rectifiers. My kit does not have (2) 4.7 uf 100v Panasonic FC capacitors, but it does have (2) unmarked blue plastic 2 leaded rectangular parts .28 inch x .23 in x .42 in. Kit also has (2) 10uf 50v electr caps. Since I am buiding 2 rectifier boards, need 2 sets of these parts... Kit also has 5 high wattage resistors: 6.8k, 4.7k, 3.0k, 1.1k, and 680 ohm. What would these be for? Should I throw this kit out and buy a new one? |
#2 | |
Banned
No need to throw out your kit. I have just message briangt for you to show him this thread so he can help you. Have you tried to email him ? |
#3 | |||
The Zobel network does not have to be used, some people decide not to use it. Your welcome to test out the differeneces and find what you like best. But for the zobel there is supposed to be a 2.7ohm 2w resistor. Brian may have found that he prefered a 2.9ohm resistor more. Quote:
The resistors, I'm a bit confused. about as well. Hope this helps. Josh
#4 | |
diyAudio Moderator Emeritus
For the power supply board, the 4.7uF capacitors were replaced with 10uF capacitors. Let me know if there is any more confusion. -- Brian |
#5 |
Yes the cap says 100n GR very small faded print.
The picture on your link is the correct parts list! Your boards unfortunately are different, but helpful to see the blue 100nf cap. Now, how about a schematic for this puppy! Thank you so much for your help so far, the pieces are coming together... I havent emailed Brian, but thank you for sending him a note. Maybe he will help.... |
| FA: BrianGT LM3875 amp in case | fireman | Swap Meet | 1 | 4th September 2006 05:40 PM |
| P3A and BrianGT's LM3875 | nina | Solid State | 5 | 19th March 2006 01:57 PM |
| LM3875 BrianGT kit not working | waltson | Chip Amps | 9 | 28th January 2006 08:00 PM |
| WTB: BrianGT LM3875 boards | guzzler | Swap Meet | 1 | 10th December 2004 10:34 PM |
| Page generated in 0.22626 seconds (43.10% PHP - 56.90% MySQL) with 10 queries |
