Old 6th May 2006, 09:17 PM   #1
alizawi is offline alizawi  Palestine
Default regulating voltage for preamp
If I want to use the +33 - 33 V rails from my power amp (lm3875) to power my preamp (which uses an lm1458 ) will the lm337 and 317 do the job? and would I have to use the chassis ground to ground my premp and voltage regualtors as well? I think these regulators are more realiable than using zenors, but feedback is appreciated.
Old 6th May 2006, 10:09 PM   #2
paulb is offline paulb  Canada
Yes, it will work and ground would be common between the two, but performance will probably be better if the preamp has its own power supply. Ground loops and associated hum may be an issue for you.
Old 7th May 2006, 01:01 AM   #3
i might eventually build a spearate power supply for it, but for now I just want to use the same supply I'm using for the power amp to see if the thing even works........I need dual 15 V rails, but those regulators are giving me some trouble.....I calculated the resistor values as specified on the data sheet, but I can't get more than 6 V on the ouput for the positive part.....maybe the resistor values i used arent the best, I'm not sure...still haven't tried the negative voltage. Anyone have experience with the lm317/337?
Old 7th May 2006, 03:42 PM   #4
LM317:
R1 = 240 and R2 = 2700 would give about 15-15.5V
Old 7th May 2006, 08:08 PM   #5
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Even simpler is to use fixed voltage regulators - 7815/7915 , for example.
Old 7th May 2006, 08:52 PM   #6
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Yes, it would be simpler, but those regs have a max input voltage of 30V so.. My guess is that itt would be risky, unnecesarily.
Old 7th May 2006, 08:57 PM   #7
L79x/L78xx has input voltages up to +/-35V.This is true for 12 to 18 volt voltage regs.
Old 7th May 2006, 10:04 PM   #8
Oops.. my bad I was referring to the LM78xx/79xx
Old 7th May 2006, 10:34 PM   #9
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Deriving +-15V for the preamp from main amplifier rais is ok as long as the regulators and the preamp are grounded in the proper place to avoid ground loops.
I use to feel like the small child in The Emperor's New Clothes tale
Old 7th May 2006, 10:58 PM   #10
the lm337 and 317 work just fine im just tryin to get the resistor values for the right voltage......but I think I can wire tthe trhing properly to avoid grounhd loops
Self regulating Class A Kees Solid State 50 14th October 2004 08:41 PM
LM3x7 HV regulating. w00t Parts 3 29th February 2004 09:42 PM
Regulating rail voltage for fans Matttcattt Everything Else 21 9th February 2004 01:47 PM
7815 not regulating. JoeBob Solid State 16 8th September 2003 12:51 PM
Page generated in 0.15493 seconds (52.65% PHP - 47.35% MySQL) with 11 queries
