Old 4th May 2006, 09:15 PM   #1
Default Snubber pics?
Does anyone have pics of a completed snubber based on the Carlosfm design located at Decibel Dungeon?
I have all the parts, but I am nervous about actually trying. Specifically, I would like to see its integration into the signal path.
Thanks,
Dominick
A real amateur enthusiast!
Old 5th May 2006, 08:28 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Oh dear!
Dominick, the snubbers are used on the caps in the power supply, not in the signal path. Anyway, here's a picture if it makes things clearer for you.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 5th May 2006, 08:41 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
Dominick22, if you take for instance 100 uF in parallel with 100 nF you'll get an impedance peak and an impedance dip.
According to simulations and measurements you should _not_ have a 100 nF (or similar value) without a resistor in series, this if you really want to avoid the peaks.
Simulations:
http://www.diyaudio.com/forums/showt...197#post546197
Real world measurements:
http://www.diyaudio.com/forums/showt...002#post548002
My suggestion how it should be done and in this case noone had come with any objections. You can also snubberize both the x000 uF package but at least the very close decoupling package should be snubberized if you if some reason want to eliminate this very small impedance peak in the 0.5-2 MHz area.
http://www.diyaudio.com/forums/attac...amp=1109343379
Before you do too much you must ask yourself what the purpose is and what the goal is. If you don't know the goal it's also hard to choose the right parts and the right circuit.
This should also be considered:
http://www.diyaudio.com/forums/showt...632#post564632
See also my sig below.
/Per-Anders (my first name) or P-A as my friends call me
Old 5th May 2006, 10:34 AM   #4
Peranders,
Thanks for the posting--I will have to dive into it later.
I am building a bi-amp for me 2 main speakers. So 2 chips for highs and 2 chips for lows. I am only snuberizing the lows.
Peter Daniel was nice enough to help me out and he already put the kits together for me so the values have been selected by someone I trust. I am just so new that I am having difficulty understanding how and where to connect what!LOL
Ill post values and such later--Thanks Nuuk and Peranders!
Dominick
Old 5th May 2006, 09:31 PM   #5
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Should read this :
http://sound.westhost.com/articles/capacitors.htm
Lukas.
Old 5th May 2006, 10:45 PM   #6
OK guys,
I have:
2 1u8 Rifa
4 1.5nf
4 100nf
4 3.3nf
4 .47R
4 .1R
4 1500R (I think they are)
So my problem is-I can get the guts of the snubber put together, but where do I actually connect to the boards? Do solder directly to the chip? If so, what and where?? And then do I just end it where the 10 uf caps are now?
Thanks,
Dominick
Old 6th May 2006, 03:44 AM   #7
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I understand you are following the description that can be found on Nuuk's site.
Solder 0.1R and 3n3 in series directly between each Panasonic 1500 cap pins (that you have presently on board, do it underneath the board, snubber cap on the ground side).
Solder 1.8uF cap across PS rails as close to chip is possible, also in a bottom layer. Follow the traces from main filter caps to see which pads are connected to those rails.
Other snubber components can be added directly on rectifiers board, as there are special spots for those parts (0.47R and 1.5nF). You can also fit there 10,000uF caps, the other caps need to be connected with wires as there is not enough space on board.
1k5 resistors are soldered directly across big cap pins.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 6th May 2006, 11:34 AM   #8
You all have ben great!
I think I can put the board together now and pretty much the rest of the network.
Any pics of snubber chip pin connections, etc.??
Thanks,
Dominick
Old 6th May 2006, 11:56 AM   #9
How do you can solder rails outlets with soldered elyts, Peter ?
Old 6th May 2006, 12:39 PM   #10
Can you be more specific, I can figure out what you mean.
www.audiosector.com
snubber p.s. wicho Chip Amps 11 21st October 2008 01:07 PM
Snubber AND non-snubber ? jimbo1968 Chip Amps 10 6th December 2005 07:49 AM
Snubber s2kov Tubes / Valves 13 30th November 2004 02:09 PM
Page generated in 0.14313 seconds (66.00% PHP - 34.00% MySQL) with 11 queries
