| Chip Amps Amplifiers based on integrated circuits |
hi,
in the summer i might be making a pair of OB speakers, i have been informed that they need to be bi-amped with a PLLXO integrated in to the amp. has anyone done this kind of thing? i was planning on using a LM3875 because of its simplicity, where in the UK can i get a power suppy for it? would it be a bad idea to have both amps in the same enclosure or build two seperate identicle enclosures? |
#2 |
Tell us more about your design choices/assumptions. If someone has enough information to give you advice on bi-amping I would guess there are some details you haven't shared.
There is some enthusiasm for OB designs on the >Loudspeakers>Fullrange Forum at diyaudio and at www.fullrangedriver.com It would be worth browsing around there and, somewhat paradoxically, doing a search on bi-amping. Use of helper woofers and/or tweeters are not uncommon on otherwise fullrange designs. |
#3 |
#4 | |
IF your speakers are efficient enough, the SMPS modules are a great PSU and you can buy them through me at Decibel Dungeon (where you can also find a lot of other infomation regarding GC's and my open baffles).
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#5 |
well the FR125S i will be using is 86dB and i will be using a woofer of simmilar efficiency.
do you sell the psu as a kit or made up? whats the difference between inverted and non-inverted amplifiers? thanks |
#6 | |
Hmmm, my speakers are 95/96 db and I'm not sure if 12 volt rails would be 'man enough' for your speakers. If you do want to try them all the infomoration is on that link I took the trouble to give you!
| LM3875 power up test.. and it crackles w/o speakers attached? | Keyoke | Chip Amps | 9 | 2nd March 2012 01:39 AM |
| Behringer crossover audiophile quality, bi/tri amping stereo speakers? | cirrus18 | Multi-Way | 25 | 29th December 2008 12:55 PM |
| speakers for lm3875 | alizawi | Chip Amps | 6 | 1st April 2006 01:08 AM |
| Augmenting the bass range of my speakers (inc. bi-amping) | SimontY | Multi-Way | 116 | 27th February 2006 03:15 PM |
| LM3875 GainClone & 4 ohm speakers | BlairHatcher | Chip Amps | 5 | 26th June 2003 11:22 AM |
| Page generated in 0.12732 seconds (56.88% PHP - 43.12% MySQL) with 10 queries |
