| Chip Amps Amplifiers based on integrated circuits |
I have a large toroid (500VA) used in a stereo gainclone. I want to add a third channel for a center channel.
My options are: 1. Use the same psu that I use for two channels also for the third one. (cheapest) 2. Build a second psu and use the transformer to feed the second psu for the third channel. (cheap) 3. Buy a new transformer and build a new psu (expensive!) The amps are Brians 3886 kits. I have the suberized board as well as the non snuberized one so I could use the better suited if one can feed three amps (the other one will be used for another amp for the surrounds). I hope I'm making myself clear. Thanks all for your help, xavier |
#2 |
You have enough VA to add a third channel,try that first. Make sure the grounding is the same as the first two amps. Use the snubbized board for the front channels
#3 | |
Thanks, xavier |
#4 | |
Yes |
| UCD Supply ST Transformer Options | Juke425 | Class D | 0 | 28th July 2008 10:14 PM |
| transformer VA and supply voltage? | AndrewT | Power Supplies | 11 | 29th May 2007 12:55 AM |
| 2 PSUs or DIY? | DragonMaster | Power Supplies | 15 | 19th April 2006 02:00 PM |
| 2A3 power supply transformer | tomchaoda | Tubes / Valves | 6 | 12th November 2004 01:24 PM |
| Page generated in 0.13437 seconds (43.22% PHP - 56.78% MySQL) with 10 queries |
